SP-320-48SMEOL
External power supply for DAS-4192, 321.6W
Description
	The SP-320-48SM external power supply is ideal for applying with the DAS-4192 IP DSLAM D-Link, providing the necessary parameters for operation of the DAS-4192.
	SP-320-48SM supports the following nominal values of characteristics: 321.6W output power, 6.7A output current and 48V output voltage. In addition, the device provides built-in protection mechanisms against overload, output voltage exceedence, short circuit and high temperatures.
General features
	Built-in protective mechanisms
	• Overload protection is triggered when the output power exceeds the nominal value of 5%-35%
	• Protection against the output voltage exceedance and short-circuit is triggered when the output voltage is from 57.6V to 67.2
	• Protection against high temperatures
	Ventilation
	• Built-in DC fan
	• Fan speed control
Certificates
Order info
SP-320-48SM External power supply for DAS-4192, 321.6W
