DAP-1353EOL EOS
Description
ULTIMATE PERFORMANCE
The D-Link RangeBooster N 650 Access Point DAP-1353 is a draft 802.11n compliant device that delivers real world performance of up to 650% faster than 802.11g wireless connection and transmission rates faster than 100Mbps wired Ethernet.1 Providing connectivity for wireless computer users and wireless LAN nodes such as print servers on the 2.4GHz frequency band, this Access Point provides a fast wireless performance while remaining fully compatible with 802.11g and 802.11b devices. Connect this RangeBooster N 650 Access Point to an Internet-enabled wired network and wirelessly share high-speed Internet. For superior performance, add other RangeBooster N 650 devices such as the RangeBooster N 650 notebook and desktop adapters, and enable a wireless coverage that extends to virtually every corner of your home or offce.
EXTENDED HOME NETWORk COVERAGE
Powered by RangeBooster N 650 Technology, this high-performance Access Point provides superior network coverage while minimizing dead spots. Utilize the three adjustable antennas to confgure optimal settings specifc to your environment. The RangeBooster N 650 Access Point is designed for use in bigger homes/offces and for users that demand higher networking performance.
EASY TO SETUP, EASY TO USE
D-Link’s Wireless Network Wizard guides you step-by-step through the installation process. Confgure this Access Point without having to call a networking expert to help you. Create a draft 802.11n wireless network with a data throughput capable of intense gaming, audio/video streaming, and large fle transfers. Delivering best-in-class wireless performance, superior network security, and enhanced network coverage, the RangeBooster N 650 Access Point is an integral piece for your next generation wireless network.
General features
STANDARDS
+ IEEE 802.11n (draft)
+ IEEE 802.11g
+ IEEE 802.11b
+ IEEE 802.3
+ IEEE 802.3u
FREQUENCY RANGE
+ 2412 to 2462MHz (North America)
+ 2412 to 2472MHz (General Europe)
EMISSION SCHEMES
DSSS, OFDM
DATA MODULATION SCHEMES
DBPSk, DQPSk, CCk and OFDM
(BPSk/QPSk/16-QAM/64-QAM)
DATA RATES 1
+ 802.11g: 6/9/12/18/24/36/48/54Mbps
+ 802.11b: 1/2/5.5/11Mbps
+ 802.11n: 30/60/90/120/180/240/270/300Mbps
TRANSMIT OUTPUT POWER 2
16dBm (typical)
EIRP
19dbm (typical)
ANTENNAS
3 detachable 3dBi Gain dipole antennas
(RP-SMA connectors)
RECEIVE SENSITIVITY (802.11b)
(Typical Sensitivity at 8% PER)
+ -84dBm at 11Mbps
+ -90dBm at 2Mbps
RECEIVE SENSITIVITY (802.11g)
(Typical Sensitivity at 10% PER, 1000-byte PDUs)
+ –86dBm at 6Mbps
+ –86dBm at 9Mbps
+ –84dBm at 12Mbps
+ –82dBm at 18Mbps
+ –78dBm at 24Mbps
+ –75dBm at 36Mbps
+ –71dBm at 48Mbps
+ –70dBm at 54Mbps
RECEIVE SENSITIVITY (draft 802.11n)
+ –88dBm (BPSk, coding rate 1/2 MCS-0)
+ –84dBm (QPSk, coding rate 1/2 MCS-1)
+ –81dBm (QPSk, coding rate 3/4 MCS-2)
+ –78dBm (16-QAM, coding rate 1/2 MCS-3)
+ –75dBm (16-QAM, coding rate 3/4 MCS-4)
+ –70dBm (64-QAM, coding rate 2/3 MCS-5)
+ –69dBm (64-QAM, coding rate 3/4 MCS-6)
+ –68dBm (64-QAM, coding rate 5/6 MCS-7)
ETHERNET INTERFACE
10/100BASE-TX port
SECURITY
+ 64/128-bit WEP data encryption
+ Wi-Fi Protected Access (WPA, WPA2)
+ MAC Address Filtering
+ 8 SSID for Network Segmentation
+ SSID broadcast disable Function
+ 802.1Q VLAN Tagging
OPERATION MODES
+ Access Point
+ WDS with AP
+ WDS
+ AP Repeater
+ Wireless Client
QOS & PERFORMANCE ENHANCEMENT
+ WMM (Wi-Fi Multimedia)
+ User Limit
DEVICE MANAGEMENT
+ Internet Explorer v6 or later; Mozilla Firefox v1.5 or later; or other Java-enabled browsers
+ Reset button
+ SNMP
+ Telnet
+ SSL/SSH protocol support
LED
+ Power
+ Status
+ WLAN
+ LAN (10/100)
POWER CONSUMPTION
9 Watts
POWER INPUT
5VDC 3A
Through external power adapter
DIMENSIONS
198 (L) x 120 (W) x 32 mm (H)
WEIGHT
325 grams (0.717 lb)
OPERATING TEMPERATURE
0°C to 40°C (32ºF to 104ºF)
STORAGE TEMPERATURE
-20°C to 65°C (-4ºF to 149ºF)
OPERATING HUMIDITY
10% to 90% (non-condensing)
STORAGE HUMIDITY
5% to 95% (non-condensing)
EMI CERTIFICATIONS
FCC Class B, CE, IC, C-Tick
SAFETY CERTIFICATION
CSA
1 Maximum wireless signal rate derived from IEEE standard 802.11g and draft 802.11n specifcations. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead, lower actual data throughput rate. All references to speed are for comparison purposes only.
2 Maximum output power setting varies according to individual countries.
Certificates
Order info
DAP-1353 RangeBooster 802.11n Access Point
