DNC-100
Nuclias Connect Controller for Managing Access Points and Switches (up to 1500 devices)
Description
Key features
• Discovery, management, configuration, and monitoring of up to 1500 devices via a single controller
• Traffic Reporting & Analytics
• Searchable Event Log
• 802.1X and external RADIUS, POP3, LDAP servers
• Intuitive user interface
• Remote Config. & Batch Config.
• Administration via Web interface
The DNC-100 is a free software controller designed to introduce users to the Nuclias solution. This product allows users to evaluate the functionality of the system in a test mode. Technical support is not provided.
The DNC-100 software controller provides centralized management of access points and switches with Nuclias Connect support through one single device and is designed for use in small-to-medium business (SMB) networks. Nuclias Connect software provides network management, monitoring and security functionalities.
Easy Management
The DNC-100 controller can manage up to 1500 D-Link access points and switches. Real-time monitoring ensures efficient use of network resources. Alerts and statistics collection significantly simplify management and optimize network performance.
Network Security & Data Privacy
In addition to standard security features, the device supports a captive portal that prevents client access until authentication is completed.
Authentication can be performed via a local user database (username/password) or through external authentication servers such as RADIUS, POP3, and LDAP.
Centralized Firmware Upgrade
Nuclias Connect allows administrators to efficiently manage and deploy firmware updates across multiple devices from a single platform. This feature eliminates the need for manual updates on each device. Administrators can updates at convenient times, minimizing network downtime and ensuring that all devices are running the latest security patches and performance improvements.
General features
System Requirements
• Large Scale Install (up to 1500 Devices) / Small Scale Install (up to 100 Devices)
CPU
• Intel 12th i7 / • Intel 12th i5
RAM
• 32G / • 16G
Storage
• 4TB / • 2TB
Ethernet NIC
• Gigabit Ethernet Card
Monitor Resolution
• 1080P
Platform
• Windows Server 2019 (64-bit) / • Windows 11 PRO (64-bit)
• Linux Ubuntu / • Linux Ubuntu
Browser
• Edge, Chrome and Safari
Minimum Connection Speed
• 20Mbps / • 10Mbps
Performance
Maximum Number of Managed Devices
• Up to 1500 Devices
Device Management
• Device discovery (L2/L3)
• Centralized management and grouping of devices based on profiles
• Group firmware/software updates
• Scheduled firmware/software updates and configuration deployment
• AP LED on/off control
Monitoring
• Dashboard
• Topology and floor plan visualization
• Reporting system
• Logging system
• Event notifications, including email alerts
Wireless Features Management
• Bandwidth Optimization
• Auto RF Management:
- Automatic Transmit Power Control (TPC)
- Automatic Channel Selection (ACS)
• Time-based Wireless Operation
• IGMP Snooping
• VLAN
• Wireless Client Isolation
• Multi-SSID
• Band Steering
• Fast Roaming (only with APs supporting Fast Roaming)
• Airtime Fairness
Security Features Management
• 802.1X
• Port Authentication
- Local Database (username/password)
- POP3 Server
- RADIUS Server
- LDAP Server
- PIN Code Authentication
- MAC Address Authentication
• MAC-based/IP-based ACLs
Network Management
• Free Nuclias Connect mobile app for iOS and Android
• Russian-language Web interface
• Configuration and system log backup
• Export of configuration and log backups to PC
• Configuration restore from saved file on PC
• Role-based administration with multiple access levels
Supported Devices
Wireless Access Points
• DAP-2620
• DAP-2622
• DAP-X2850
• DAP-3666
• DAP-X3060
• DAP-X3060OU
• DAP-2695
• DAP-2680
Switches
• DGS-1100-10MPV2
• DGS-1100-10MPPV2
• DGS-1100-16V2
• DGS-1100-24PV2
• DGS-1100-24V2
• DGS-1100-26MPV2
• DGS-1100-26MPPV2
• DGS-1210-10
• DGS-1210-10MP
• DGS-1210-10P
• DGS-1210-20
• DGS-1210-26
• DGS-1210-28
• DGS-1210-28MP
• DGS-1210-28P
• DGS-1210-52
• DGS-1210-52MP
• DGS-1210-08P
• DGS-1210-16
• DXS-1210-10TS
• DXS-1210-12SC
• DXS-1210-12TC
• DXS-1210-16TC
• DMS-1250-10S
• DMS-1250-10SP
• DMS-1250-10SPL
• DMS-1250-12TP
• DMS-3130-30PS
• DMS-3130-30TS
• DXS-3130-28
• DXS-3130-28P
Certificates
Order info
DNC-100
