DWL-G520EOL EOS
Wireless 108 G PCI Card
Description
ENHANCED WIRELESS CONNECTIVITY
The D-Link AirPlus Xtreme G™ DWL-G520 Wireless PCI Card delivers a cost-effective wireless upgrade for desktop PCs. Enhance your Internet experience with a faster wireless connection and enjoy smooth digital phone calls, gaming, downloading, and video streaming. The adapter’s powerful integrated antenna offers an operating range of up to 100 meters indoors and 400 meters outdoors.
TURBO MODE FOR MAXIMUM PERFORMANCE
This high-performance PCI adapter is designed for users who demand the most from their wireless network. Powered by D-Link Wireless 108 G technology, the DWL-G520 provides wireless transfers of up to 108Mbps using Turbo mode when used in conjunction with a compatible AirPlus Xtreme G 802.11g router. The adapter is also seamlessly interoperable with 802.11b wireless networks. The DWL-G520 supports WPA/WPA2 security and WEP data encryption to protect your personal information and prevent potential intruders.
EFFORTLESSLY UPGRADE AN EXISTING NETWORK
Plug-and-play installation allows this card to be quickly mounted in your PC for immediate operation. The D-Link Quick Install Wizard guides you through a straightforward setup process. Your PC can be quickly confgured without ever having to call a networking expert for assistance. A D-Link Wireless Connection Management utility is also included to keep track of any frequently accessed networks.
General features
SYSTEM REQUIREMENTS
+  Windows 98 SE, ME, XP SP2, 2000 SP4, or Vista
+  CD-ROM drive
+  20MB hard disk space
+  Available PCI slot
STANDARDS
+  IEEE 802.11g
+  PCI 2.3
MEDIA ACCESS CONTROL PROTOCOL
+  CSMA/CA with ACK
NETWORK ARCHITECTURE TYPES
+  Ad-Hoc mode
+  Infrastructure mode
FREQUENCY RANGE
+  2.4 - 2.4835 GHz
OPERATING CHANNELS
+  US (FCC): 11
+  Europe (ETSI): 13
+  Canada (DOC): 11
NETWORK TRANSFER RATE1/MODULATION TECHNIQUE
+  802.11b: 11Mbps, 5.5Mbps: CCK
   2Mbps: DQPSK 1Mbps: DBPSK
+  802.11g: 54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 9Mbps, 6Mbps: OFDM
   (Orthogonal Frequency Division Multiplexing)
RECEIVE SENSITIVITY
(FOR 802.11B)
+  1Mbps: -92dBm
+  2Mbps: -88dBm
+  5.5Mbps: -86dBm
+  11Mbps: -84dBm
RECEIVE SENSITIVITY
(FOR 802.11G)
+  6Mbps: -88dBm
+  9Mbps: -85dBm
+  12Mbps: -85dBm
+  18Mbps: -81dBm
+  24Mbps: -77dBm
+  36Mbps: -73dBm
+  48Mbps: -71dBm
+  54Mbps: -70dBm
TRANSMIT OUTPUT POWER
(FOR 802.11B)
+  1Mbps, 2Mbps, 5.5Mbps, 11Mbps: 16dBm to 18dBm
(FOR 802.11G)
+  6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps: 16dBm to 18dBm
+  36Mbps: 15dBm to 17dBm
+  48Mbps: 14dBm to 16dBm
+  54Mbps, 108Mbps: 13dBm to 15dBm
ANTENNA
+  External dipole antenna with detachable reverse SMA connector
OPERATING RANGE 2
+  Indoors: Up to 100 meters (328 feet)
+  Outdoors: Up to 400 meters (1,312 feet)
SECURITY
+  64/128/152-bit WEP data encryption
+  WPA EAP/PSK, WPA2 EAP/PSK
+  TKIP, AES support
Certificates
Order info
DWL-G520  Xtreme G+ 2.4GHz Wireless PCI Adapter
Pictures
DWL-G520
Front view
Downloads
Support Resources
