![](/up/prod/600/DWL-3610AP_A1.jpg)
DWL-3610APEOL EOS
Selectable Dual-Band 802.11n/ac Unified Wireless Access Point
Description
The DWL-3610AP Selectable Dual-Band 802.11n/ac Unified Wireless Access Point is designed for small to medium businesses and enterprises, providing unparalleled bandwidth and flexibility for medium to large scale Wi-Fi networks. Featuring the latest 802.11ac technology on its 5 GHz band, the DWL-3610AP allows you to deploy more devices and provide greater throughput for your wireless clients.
Centrally Managed
When working in conjunction with D-Link Unified Controllers, the DWL-3610AP can be centrally
managed. This allows for a large number of APs to be deployed and managed easily and efficiently. Once the APs are discovered by the controller, the administrator can push configuration to them as a group, instead of doing so individually. Additionally, Radio Frequency (RF) resource management allows wireless coverage to be managed centrally, proving the best coverage possible for wireless clients.
Self-Configuring Cluster
For small businesses that need to deploy multiple APs but lack the resources for complex network management, the DWL-3610AP self-configuring cluster allows a small number of DWL-3610AP access points to be set to form a self-configuring cluster. Once the administrator configures one access point, the same configuration can then be applied to all remaining APs, making setting up your wireless business network a breeze.
Performance Upgrade
The DWL-3610AP features an upgraded CPU, providing increased performance over its predecessor. The internal omnidirectional antenna extends its reach, eliminating dead spots and filling hard-to-reach places. A selectable radio mode allows the DWL-3610AP to work on either the 2.4 Ghz band or the 5 GHz band, providing speeds of up to 300 Mbps* for 802.11n, and 867 Mbps* for 802.11ac. Airtime fairness ensures that equal airtime is given to each client, providing increased performance even if slower devices are connected.
Automatic RF Management**
When access points are deployed in close proximity to each other, there may be interference between channels if RF management is not implemented. When a DWL-3610AP senses a neighbor nearby, it will automatically select a non-interfering channel. This greatly reduces RF interference and will allow the administrator to deploy APs more densely. To further minimize interference, when a nearby AP is on the same channel, the DWL-3610AP will automatically lower its transmission power. When, for whatever reason, the nearby AP is no longer present, the DWL-3610AP will increase its transmission power to expand coverage.
Quality of Service
The DWL-3610AP supports 802.1p Quality of Service (QoS) for enhanced throughput and better performance of time-sensitive traffic like VoIP and streaming DSCP. The DWL-3610AP supports Wi-Fi Multimedia (WMM), so in the event of network congestion, time-sensitive traffic can be given priority ahead of other traffic. Furthermore, when a number of DWL-3610AP units are in close proximity to each other, an access point will refuse new association requests once its resources are fully utilized, allowing the association request to be picked up by a neighboring unit, distributing the load over multiple APs.
*Maximum wireless signal rate derived from IEEE standard 802.11ac and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
**This feature is available when Unified AP is used in conjunction with D-Link's line of Unified Wireless Switches/Controllers.
General features
Interfaces
• 802.11b/g/n 2.4 GHz wireless
• 802.11ac/a/n 5 GHz wireless
• 10/100/1000BASE-T LAN (PoE) port
• Console port (RJ-45)
Antenna
• Internal omnidirectional antennas with 3 dBi for 5 GHz, 3 dBi for 2.4 GHz
Operating Frequency
• 2400 to 2483.5 MHz
• 5150 to 5850 MHz
System Management
• Web-based user interface (HTTP/HTTPS)
• Serial console (RJ-45)
• SNMP (v1/v2c/v3)
• Telnet/SSH
SSID Security
• Up to 16 SSIDs
• 802.1Q VLAN
• Station Isolation
Wireless Security
• WPA Personal/Enterprise
• AES and TKIP
Detection & Prevention
• Rogue and valid AP classification
Authentication
• MAC address filtering
Wireless speed*
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n: 6.5 ~ 300 Mbit/s (MCS0 ~ MCS15)
• IEEE 802.11ac: 6.5 ~ 867 Mbit/s
Transmitter Output Power**
• IEEE 802.11a:
18±2 dBm at 6~36 Mbit/s
17±2 dBm at 48~54 Mbit/s
• IEEE 802.11b:
16±2 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
19±2 dBm at 6~18 Mbit/s
18±2 dBm at 24~54 Mbit/s
• IEEE 802.11n:
2.4 GHz/HT-20:
19±2 dBm at MCS0-MCS5, MCS8-MCS13
18±2 dBm at MCS6-MCS7, MCS14-MCS15
2.4 GHz/VHT-20:
17±2 dBm at MCS8
2.4 GHz/HT-40:
16±2 dBm при MCS0-MCS15
2.4 GHz/VHT-40:
5 GHz/VHT-20:
17±2 dBm at MCS0-MCS6
16±2 dBm at MCS7
5 GHz/VHT-40:
15±2 dBm at MCS0-MCS7
• IEEE 802.11ac:
VHT-20:
16±2 dBm at MCS7
14±2 dBm at MCS8
VHT-40:
14±2 dBm at MCS8-MCS9
VHT-80:
10±2 dBm at MCS0-MCS9
Receiver Sensitivity
• IEEE 802.11a:
-82±2 dBm at 6 Mbit/s
-81±2 dBm at 9 Mbit/s
-79±2 dBm at 12 Mbit/s
-77±2 dBm at 18 Mbit/s
-74±2 dBm at 24 Mbit/s
-70±2 dBm at 36 Mbit/s
-66±2 dBm at 48 Mbit/s
-65±2 dBm at 54 Mbit/s
• IEEE 802.11b:
-89±2 dBm at 2 Mbit/s
-83±2 dBm at 11 Mbit/s
• IEEE 802.11g:
• IEEE 802.11n:
2.4 GHz/HT-20:
-82 dBm at MCS0/8
-79 dBm at MCS1/9
-77 dBm at MCS2/10
-74 dBm at MCS3/11
-70 dBm at MCS4/12
-66 dBm at MCS5/13
-65 dBm at MCS6/14
-64 dBm at MCS7/15
2.4 GHz/HT-40:
-79 dBm at MCS0/8
-76 dBm at MCS1/9
-74 dBm at MCS2/10
-71 dBm at MCS3/11
-67 dBm at MCS4/12
-63 dBm at MCS5/13
-62 dBm at MCS6/14
-61 dBm at MCS7/15
5 GHz/HT-20:
-82 dBm at MCS0/8
-79 dBm at MCS1/9
-77 dBm at MCS2/10
-74 dBm at MCS3/11
-70 dBm at MCS4/12
-66 dBm at MCS5/13
-65 dBm at MCS6/14
-64 dBm at MCS7/15
5 GHz/HT-40:
-79 dBm at MCS0/8
-76 dBm at MCS1/9
-74 dBm at MCS2/10
-71 dBm at MCS3/11
-67 dBm at MCS4/12
-63 dBm at MCS5/13
-62 dBm at MCS6/14
-61 dBm at MCS7/15
• IEEE 802.11ac:
VHT-20:
-82 dBm at MCS0
-79 dBm at MCS1
-77 dBm at MCS2
-74 dBm at MCS3
-70 dBm at MCS4
-66 dBm at MCS5
-65 dBm at MCS6
-64 dBm at MCS7
-59 dBm at MCS8
-57 dBm at MCS9
VHT-40:
-79 dBm at MCS0
-76 dBm at MCS1
-74 dBm at MCS2
-71 dBm at MCS3
-67 dBm at MCS4
-63 dBm at MCS5
-62 dBm at MCS6
-61 dBm at MCS7
-56 dBm at MCS8
-54 dBm at MCS9
VHT-80:
-76 dBm at MCS0
-73 dBm at MCS1
-71 dBm at MCS2
-68 dBm at MCS3
-64 dBm at MCS4
-60 dBm at MCS5
-59 dBm at MCS6
-58 dBm at MCS7
-53 dBm at MCS8
-51 dBm at MCS9
Physical Parameters
Dimensions
• Diameter: 160 mm
• Height: 45 mm
Weight
• 0.26 kg
Power Supply
• 12 V/1 A external power adapter
• 802.3af PoE
Max. Power Consumption
• 6.2 W
Enclosure
• Bottom cover – plastic
• Top cover – plastic
Temperature
• Operating: 0 to 40°C
• Storage: -20 to 65°C
Humidity
• Storage: 10% to 95% non-condensing
Certifications
• CE
• FCC
• IC
• cUL+UL
• LVD
• RCM
• NCC
• BSMI
* Maximum wireless signal rate derived from IEEE standard 802.11ac and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
** Maximum power output varies in each country depending on local power regulations.
Certificates
Order info
