DAP-1360/AEOL EOS
Wireless N300 Access Point & Router
Description
Wireless Interface
Using DAP-1360, you are able to quickly create a wireless network and let your relatives or employees connect to it virtually anywhere (within the operational range of your wireless network). The access point can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The device supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, different operation modes (access point, router, client), WPS, WDS, WMM.
Access Point Mode
You are able to use DAP-1360 switched to the access point mode to create a wireless network or to connect to a wired router.
Router Mode
You are able to connect DAP-1360 switched to the router mode to a cable or DSL modem or to a private Ethernet line and use a high-speed Internet connection to successfully fulfill a wide range of professional tasks.
“Client” Function
The “client” function in the access point mode allows using DAP-1360 as a wireless client and a wireless repeater, in the router mode as a WISP repeater.
Security
In the router mode, the DAP-1360 device includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of the DAP-1360 device via the user-friendly web-based interface (the interface is available in several languages).
Now you can simply update the firmware: the access point itself finds approved firmware on D-Link update server and notifies when ready to install it.
General features
Hardware
WAN Interface
• 1 10/100BASE-TX Ethernet port for cable or DSL modem or private Ethernet line
LAN Interface
WLAN Interface
• IEEE 802.11n (up to 300Mbps)
• IEEE 802.11b/g
Antenna
• Two 5dBi detachable omnidirectional antennas
• RP-SMA connector
Frequency Range
• 802.11b
2400 ~ 2497MHz ISM band
• 802.11g
2400 ~ 2483.5MHz ISM band
• 802.11n
Data Rate
• 802.11b
11, 5.5, 2, and 1Mbps
• 802.11g
54, 48, 36, 24, 18, 12, 9, and 6Mbps
• 802.11n
MCS
GI3=800ns
GI=400ns
20MHz (Mbps)
40MHz (Mbps)
20MHz (Mbps)
40MHz (Mbps)
0
6,5
13,5
7,2
15
1
13
27
14,4
30
2
19,5
40,5
21,7
45
3
26
54
28,9
60
4
39
81
43,3
90
5
52
108
57,8
120
6
58,5
121,5
65
135
7
65
135
72,2
150
8
13
27
14,4
30
9
26
54
28,9
60
10
39
81
43,3
90
11
52
108
57,8
120
12
78
162
86,7
180
13
104
216
115,6
240
14
117
243
130
270
15
130
270
144,4
300
Modulation Schemes
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Transmitter Output Power
• 802.11b (typical at room temperature 25 °C)
17dBm (±1.5dB) at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
17dBm (±1.5dB) at 6Mbps
17dBm (±1.5dB) at 9Mbps
17dBm (±1.5dB) at 12Mbps
16dBm (±1.5dB) at 18Mbps
16dBm (±1.5dB) at 24Mbps
15dBm (±1.5dB) at 36Mbps
15dBm (±1.5dB) at 48Mbps
15dBm (±1.5dB) at 54Mbps
• 802.11n (typical at room temperature 25 °C)
HT-20
HT-40
16.5dBm (±1.5dB) at MCS0/8
16.5dBm (±1.5dB) at MCS1/9
16.5dBm (±1.5dB) at MCS2/10
16dBm (±1.5dB) at MCS3/11
16dBm (±1.5dB) at MCS4/12
15.5dBm (±1.5dB) at MCS5/13
15dBm (±1.5dB) at MCS6/14
14dBm (±1.5dB) at MCS7/15
Receiver Sensitivity
• 802.11b (typical at PER = 8% (1000-byte PDUs))
-82dBm at 1Mbps
-80dBm at 2Mbps
-78dBm at 5.5Mbps
-76dBm at 11Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs))
-85dBm at 6Mbps
-84dBm at 9Mbps
-82dBm at 12Mbps
-80dBm at 18Mbps
-77dBm at 24Mbps
-73dBm at 36Mbps
-69dBm at 48Mbps
-68dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs))
HT-20
HT-40
-82dBm at MCS0/8
-79dBm at MCS0/8
-79dBm at MCS1/9
-76dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS2/10
-74dBm at MCS3/11
-71dBm at MCS3/11
-70dBm at MCS4/12
-67dBm at MCS4/12
-66dBm at MCS5/13
-63dBm at MCS5/13
-65dBm at MCS6/14
-62dBm at MCS6/14
-64dBm at MCS7/15
-61dBm at MCS7/15
Software
Operation Modes
• Access point mode
• Router mode
Network Functions
• WAN connection types
PPPoE
Static IP
Dynamic IP
Static IP + PPPoE
Dynamic IP + PPPoE
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
• DHCP server/relay
• DNS relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIP
• Support of UPnP IGD
• WAN ping respond
• Support of SIP
• Support of RTSP
• PPPoE pass through
Wireless Connection
• Supported security settings
WEP
WPA/WPA2 Personal
WPA/WPA2 Enterprise
• MAC filter
• Managing connected stations
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
• Advanced settings
• WDS
• “Client” function (access point mode)
Wireless network client
Wireless network repeater
• “Client” function (router mode)
WISP repeater
Firewall Functions
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
Configuration and Management
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote logging
• Ping function
• Traceroute utility
Physical and Environmental
LEDs
• Power
• WLAN
• WPS
• LAN
• Internet
Power
• External power adapter DC 12V/0.5А
Buttons
• Power on/off button
• WPS/RESET button
Operating Temperature
• From 0 to 40 C (from 32 to 104 F)
Storage Temperature
• From -20 to 65 С (from -4 to 149 F)
Operating Humidity
• From 10% to 90% non-condensing
Storage Humidity
• From 5% to 95% non-condensing
Certificates
Order info
DAP-1360/A Wireless N300 Access Point & Router
Pictures
DAP-1360/A
Back view
View from the right
Front view
Downloads
Support Resources
