DWL-8710APEOL EOS
802.11n/ac Unified Wireless Outdoor Access Point
Description
The DWL-8710AP is an outdoor Dual-Band 802.11n/ac Wi-Fi Access Point designed specifically for deployment in business and campus environments. Highly manageable and capable of blazing speeds, the DWL-8710AP integrates seamlessly into existing network infrastructure and can be easily scaled to meet future demands.
High Performance
The DWL-8710AP is equipped with two radio transceivers. The first is a 2.4 GHz 2x2 IEEE 802.11n interface that supports up to 300 Mbps of network throughput while the second one is a 5 GHz 2x2 IEEE 802.11ac interface, capable of up to 867 Mbps of network throughput. The DWL-8710AP also features two Gigabit Ethernet network interfaces, designed to allow the administrator to easily bridge other networking devices into the network, such as a camera or another Wi-Fi access point.
Robust Design
The DWL-8710AP is IP67-compliant and is designed to operate in harsh outdoor environments and temperatures ranging from -30 up to 60 ̊C. In addition, all network interfaces are protected against electrical surges, enabling the device to be placed in areas where there is a risk of being struck by lightning.
Unified Management
When deployed in conjunction with D-Link’s line of Unified Wireless Switches, up to 1024 DWL-8710APs may be centrally managed and provisioned, enabling the administrator to scale the Wi-Fi network to cover larger areas.
Security
The DWL-8710AP supports all the latest in Wi-Fi security, including WPA, WPA2, and 802.1X. In addition, the DWL-8710AP supports up to 32 Virtual Access Points (VAP), which gives the administrator the flexibility to easily assign access privileges to different classes of users. When used together with D-Link’s line of Unified Wireless Switches, security can be taken to a new level. Rogue APs in the network may be easily detected, and the administrator will be immediately notified of any security threat.
Automatic Radio Frequency (RF) Management
When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. When a DWL-8710AP senses a neighbor AP nearby, RF management will make it so that the DWL-8710AP will automatically select a non-interfering channel. This greatly reduces RF interference and makes it possible to deploy APs more densely. To further minimize interference, the DWL-8710AP will automatically lower its transmitting power when an adjacent AP is operating on the same channel. If a nearby AP is no longer present, the DWL-8710AP will dynamically increase its transmitting power again to increase wireless coverage.
Quality of Service
The DWL-8710AP supports Wi-Fi Multimedia (WMM), which prioritizes time-sensitive traffic in the event of a network data congestion. Furthermore, when a number of DWL-8710APs are in close proximity with each other, an access point will refuse new association requests once its resources are fully utilized. Instead, the association request will be picked up by a neighboring unit. This feature ensures that a single access point is never overloaded while others remain underutilized. Furthermore, the administrator has the option to limit the bandwidth on a per-user basis, avoiding scenarios where a particular client might use up all the available bandwidth, affecting the performance of other users on the network.
General features
Interfaces
• 802.11a/g/n/ac 2x2 MIMO
• 2 x 10/100/1000 LAN ports
• 4 N-Type antenna connectors (2 x 2.4 GHz, 2 x 5 GHz)
Antenna
• 2 x 7 dBi gain for 5 GHz radio
• 2 x 5 dBi gain for 2.4 GHz radio
• 4 external omni-directional antennas included
Power Method
• PoE-powered through port LAN1 marked PoE-Input
Operating Frequency
• 2400 MHz to 2483.5 MHz ISM band
• 5.180 GHz to 5.240 GHz
• 5.280 GHz to 5.320 GHz
• 5.500 GHz to 5.700 GHz
• 5.745 GHz to 5.825 GHz
Operating Channels
• 1 to 13 channels for 2.4 GHz band (per country code)
• 36 to 165 channels for 5 GHz band (per country code)
Web-Based User Interface
• HTTP/HTTPS
SSID Security
• Up to 32 SSIDs, 16 per radio
• 802.1Q VLAN
• Station Isolation
Wireless Security
• WPA/WPA2 Personal/ Enterprise
• AES
• TKIP
Detection & Prevention
• Rogue and Valid AP Classification
Authentication
• MAC Address Filtering
Dimensions
• 250 x 220 x 45 mm excluding mounting base
Weight
• 2053 g with antennas attached
• 1795 g without antennas attached
Power Consumption
• 16.5 W maximum
Power over Ethernet
• 802.3at compliant Power over Ethernet
Enclosure
• Metal and polycarbonate
• IP67-rated housing
• UL2043 certified
• GORE® Vent
Temperature
• Operating: -30 to 60 °C
• Storage: -30 to 70 °C
Humidity
Certifications
• CE
• EN 301 893 V1.7.1 (2012-06) (DFS/TPC)
• EN 300 328 V1.8.1 (2012-06)
• FCC
• IC
• cUL
• C-Tick
• NCC
• Wi-Fi
• LVD
• UL204
Certificates
Order info
DWL-8710AP 802.11n/ac Unified Wireless Outdoor Access Point
