DIR-615/K2AEOL EOS
Wireless N300 Router
Description
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-615 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Configuration and Management
You can configure and manage the settings of the wireless router DIR-615 via the user-friendly web-based interface (the interface is available in several languages).
Wireless Interface
Using the DIR-615 device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps). The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
General features
Hardware
WAN Interface
• 1 10/100BASE-TX Ethernet port for cable or DSL modem or private Ethernet line
LAN Interface
• 4 10/100BASE-TX Ethernet ports
WLAN Interface
• IEEE 802.11n (up to 300Mbps)
• IEEE 802.11b/g
Frequency Range
• 802.11b
• 2400 ~ 2497MHz ISM band
• 802.11g
• 2400 ~ 2483.5MHz ISM band
• 802.11n
• Channel frequency for HT20: 2412 ~ 2472MHz
• Channel frequency for HT40: 2422 ~ 2462MHz
Wireless Connection Rate
• 802.11b
• 11, 5.5, 2, and 1Mbps
• 802.11g
• 54, 48, 36, 24, 18, 12, 9, and 6Mbps
• 802.11n
• 6.5~300Mbps
Transmitter Output Power
• 802.11b
• Typical 16dBm (+/-2dB) at 1, 2, 5.5, 11Mbps at room temperature 25 °C
• 802.11g
• Typical 14.5dBm (+/-2dB) at 6, 9, 12, 18, 24, 36, 48, 54Mbps at room temperature 25°C
• 802.11n
• HT20: typical 14.5dBm (+/-2dB) at MCS-0 ~ MCS-15 at room temperature 25 °C
• HT40: typical 14dBm (+/-2dB) at MCS-0 ~ MCS-15 at room temperature 25°C
Receiver Sensitivity
• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature)
• -79dBm for 11Mbps
• -82dBm for 5.5Mbps
• -84dBm for 2Mbps
• -84dBm for 1Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature)
• -82dBm at 6Mbps
• -81dBm at 9Mbps
• -79dBm at 12Mbps
• -77dBm at 18Mbps
• -74dBm at 24Mbps
• -70dBm at 36Mbps
• -66dBm at 48Mbps
• -65dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs))
HT20
• -82dBm at MCS0
• -79dBm at MCS1
• -77dBm at MCS2
• -74dBm at MCS3
• -70dBm at MCS4
• -66dBm at MCS5
• -65dBm at MCS6
• -64dBm at MCS7
HT40
• -79dBm at MCS0
• -76dBm at MCS1
• -74dBm at MCS2
• -71dBm at MCS3
• -67dBm at MCS4
• -63dBm at MCS5
• -62dBm at MCS6
• -61dBm at MCS7
Software
Network Functions
• WAN connection types
• PPPoE
• Static IP
• Dynamic IP
• PPTP/L2TP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
• DHCP server and client
• DNS relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• Support of VLAN
• WAN ping respond
Wireless Connection
• Supported security settings
• WEP
• WPA/WPA2 Personal
• WPA/WPA2 Enterprise
• MAC filter
• Advanced settings
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
Firewall Functions
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Ping function
• Support of remote logging
• Automatic synchronization of system time with NTP server
• Traceroute utility
Certificates
Order info
DIR-615/K2 Wireless N300 Router
