ANT24-0230EOL EOS
Triple 2.4GHz Omni-Directional Antenna, 2dBi
Description
Optimal Performance
Triple 2.4GHz omni-directional D-Link ANT24-0230 antenna is a universal antenna, designed to improve the performance of your Xtreme N adapter (DWA-552) and Router (DIR-655) from the D-Link company, as well as the RangeBooster N 650 Adapter (DWA- 547) and Router (DIR-635) from the D-Link company.
Indoor Installation
Triple 2.4GHz omni-directional D-Link ANT24-0230 antenna comes with an extension cable that allows you to place the antenna close to the adapter and the router. Thus, it is possible to have a functioning wireless network by placing a desktop computer under the table, and the antenna ANT24-0230 on the table, or attach it to the wall. You might also consider the location of the router in a closet or a confined space in which you can still achieve optimal wireless coverage by using a triple 2.4GHz omni-directional antenna.
Installation Flexibility and Increased Productivity
Triple 2.4GHz omni-directional D-Link ANT24-0230 antenna increases the flexibility of the plant for the adapter and the router, allowing you to increase network capacity.
General features
Minimum system requirements
• Network Device 2.4GHz (802.11n), equipped with a detachable antenna with RP-SMA
Frequency band
• From 2.4GHz to 2.5GHz
Resistance
• 50 Ohms (nominal)
VSWR
• 1.92 (maximum)
Directionality
• Omni-directional
Polarization
• Linear, vertical
Allowable power
• 1W
The antenna design
• Dipole (3 transmitter antenna)
The maximum gain
(Loss of the cable)
• 1.8dBi
Antenna material
• TPE, PBT, ABS
Antenna colour
• Black
The attenuation in the cable (1.2m)
• 2dB
Cable
• RG-174 50 Ohms
Cable connectors
• 3 RP-SMA plug
Cable length
• 1.2m
Cable colour
• Black
Certificates
Order info
ANT24-0230 Triple 2.4GHz Omni-Directional Antenna, 2dBi
