DCS-930EOL EOS
Wireless N Home Network Camera
Description
The DCS-930/930L is a unique and versatile surveillance solution for your home or small office. Unlike a traditional webcam, the DCS-930/930L is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance. Simple installation and an intuitive web-based interface offer easy integration with your Ethernet or 802.11n wireless network. The DCS-930/930L also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
Wireless n connectivity
The DCS-930/930L includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream high-quality video to remote sites and mobile devices. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS-930/930L also includes a standard Ethernet port for connections to traditional wired networks.
MyDLink for fast and convenient access to your Video (DCS-930L)
Convenient mydlink™ zero-configuration setup gets you up and running in no time – just connect the DCS-930L, then register the device on the mydlink™ website. The DCS-930L will then automatically configure itself and connect to the mydlink™ service allowing for convenient access to your video feeds from anywhere with Internet access.
Easy to configure and Operate
This network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com), and remotely access the camera without having to remember the IP address. You may also view up to 32 cameras from a central location using the included D-ViewCam software. D-ViewCam has a robust set of features including automated e-mail alerts which can instantly inform administrators of suspicious or unusual activities.
General features
SYSTEM REQUIREMENTS
• Operating System: Microsoft Windows XP, Vista, Windows 7
• Internet Explorer 6 or above , Firefox 3.5 or above, Safari 4
• Networking Protocol ƒ IPV4, ARP, TCP, UDP, ICMP ƒ DHCP Client
• NTP Client (D-Link) ƒ DNS Client
• DDNS Client (Dyndns and D-Link) ƒ SMTP Client
• FTP Client ƒ HTTP Server ƒ PPPoE
• UPnP Port Forwarding ƒ LLTD
• UPnP-X1
BUILT-IN NETWORK INTERFACE
• 10/100BASE-TX Fast Ethernet
• 802.11b/g/n WLAN
WIRELESS CONNECTIVITY
• 802.11b/g/n Wireless with WEP/WPA/ WPA2 security
WIRELESS TRANSMIT OUTPUT POWER
• 16 dbm for 11b, 12 dbm for 11g, 12 dbm for 11n (typical)
SDRAM ƒ
• 32 MB
FLASH MEMORY ƒ
• 4 MB
RESET BUTTON
• Reset to factory default
VIDEO Codecs ƒ MJPEG
• JPEG for still images
VIDEO FEATURES
• Adjustable image size and quality ƒ Time stamp and text overlay ƒ Flip and Mirror
RESOLUTION
• ƒ640 x 480 at up to 20 fps ƒ 320 x 240 at up to 30 fps ƒ 160 x 120 at up to 30 fps
LENS
• Focal length: 5.01 mm, F2.8
SENSOR
• VGA 1/5 inch CMOS Sensor
Minimum Illumination ƒ
• 1 lux @ F2.8
View Angle ƒ
• Horizontal: 45.3° ƒ
• Vertical: 34.5° ƒ
• Diagonal: 54.9°
DIGITAL ZOOM ƒ
• Up to 4x
3A CONTROL
• AGC (Auto Gain Control)
• AWB (Auto White Balance)
• AES (Auto Electronic Shutter)
Power
• Input: 100-240 V AC, 50/60 Hz ƒ Output: 5 V DC, 1.2 A
• External AC-to-DC switching power adapter
DIMENSIONS (W x D x H)
• Including the bracket and stand: 65.8 x 65 x 126 mm
• Camera only: 27.2 x 60 x 96 mm
WEIGHT
• 76.9 g (without bracket and stand)
MAX POWER CONSUMPTION
• 2 W
Operation Temperature
• 0 ˚C to 40 ˚C (32 ˚F to 104 ˚F)
Storage Temperature ƒ
• -20 ˚C to 70 ˚C (-4 ˚F to 158 ˚F)
Humidity
• 20-80% RH non-condensing
Emission (EMI), Safety & Other Certifications
• FCC Class B ƒ
• IC
• C-Tick ƒ
• CE
Certificates
Order info
DCS-930 Wireless N Home Network Camera
Pictures
DCS-930/A
Front view
Downloads
Support Resources
