DAP-1150/NB1EOL EOS
Wireless Access Point Supporting Router Mode
Description
Wireless Interface
Using DAP-1150, you are able to quickly create a wireless network and let your relatives or employees connect to it virtually anywhere (within the operational range of your wireless network). The access point can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 150Mbps).
The device supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WDS, WMM.
Security
In the router mode, the DAP-1150 device includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Access Point Mode
You are able to use DAP-1150 switched to the access point mode to create a wireless network or to connect to a wired router.
Router Mode
You are able to connect DAP-1150 switched to the router mode to a cable or DSL modem or to a private Ethernet line and use a high-speed Internet connection to successfully fulfill a wide range of professional tasks.
“Client” Function
DAP-1150The “client” function in the access point mode allows using DAP-1150 as a wireless client and a wireless repeater, in the router mode as a WISP repeater.
Configuration and Management
DAP-1150You can configure and manage the settings of the DAP-1150 device via the user-friendly web-based interface (the interface is available in several languages).
General features
Hardware
• LAN Interface:1 10/100BASE-TX Ethernet port with auto MDI/MDIX.
WLAN Interface:
• IEEE 802.11b/g/n.
Software
Operation Modes:
• Access point mode
• Router mode.
Network Functions:
• WAN connection types:
PPPoE
Static IP
Dynamic IP
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
• DHCP server and client
• DNS relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIPUPnP.
Wireless Connection:
• WLAN splitting (up to 4 SSIDs)
• Supported security settings:
WEP
WPA/WPA2 Personal
WPA/WPA2 Enterprise
• MAC filter
• Managing connected stations
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
• Advanced settings
• WDS
• “Client” function (access point mode):
• Wireless network client
• Wireless network repeater
• “Client” function (router mode):WISP repeater.
Firewall Functions:
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacksVirtual servers.
Configuration and Management:
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote loggingAutomatic synchronization of system time with NTP server (router mode).
Physical and Environmental
LEDs:
• Power
• LAN/WAN
• WLAN.
Power:
• External power adapter DC 5V/1.2А
• Reset to Factory Defaults button.
Operating Temperature:
• from 0 to 55 0C (from 32 to 131 0F).
Operating Humidity:
• from 10% to 90% non-condensing.
Certification:
• CE
• FCC Class B
• C-Tick
• Wi-Fi.
Certificates
Order info
DAP-1150/NB1 Wireless Access Point Supporting Router Mode
