![](/up/prod/600/DAP-1525.jpg)
DAP-1525EOL EOS
Wireless N300 Dual Band Access Point/Bridge
Description
Fast, reliable connections to your devices
The D-link Wi-Fi Booster allows you to create reliable, high-speed connections to your wired and wireless devices. It features dual-band 802.11n wireless with D-link’s Smart Beam technology, and allows you to choose either the 2.4GHz wireless band for compatibility, or the 5GHz wireless band for interference free connections with compatible devices. The Wi-Fi Booster also includes four gigabit LAN ports with easy to use port-based Quality of service (QoS); simply plug in your wired devices in order of importance, and the Wi-Fi Booster will automatically configure QoS for you. You can even connect a USB printer or storage drive and share it through D-link’s SharePort feature.
By using D-link’s unique smart Antenna design, the Wi-Fi Booster automatically adjusts its coverage to provide an optimized connection for each authorized wireless client. This extends coverage, minimizes interference, provides higher wireless speeds, and even helps to save energy by adjusting the amount of power used for wireless connections.
Double the wireless coverage
The Wi-Fi Booster’s multiple antenna design gives you double the wireless coverage when compared to a standard antenna, eliminating dead spots.
Connect your devices from farther away than ever before, and enjoy a solid connection to your network, inside, outside, and around your house, even across different floors.
Stay safe and secure
Prevent unauthorized access to your network with WPA/WPA2 wireless encryption, which keeps your network traffic secure from prying eyes. You can also set up a Guest Zone to provide limited wireless access on a separate wireless network from your own devices, and wireless scheduling allows you to shut down your wireless network when you are away from your home or office.
General features
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
Device interfaces
• 802.11n/g/b/a wireless LAN
• 4 10/100/1000BASE-T Gigabit LAN ports
• USB 2.0 port
Antenna type
• Internal smart antennas with Smart Beam technology
Operation mode
• Access Point (AP)
• Bridge*
Security
• WPA and WPA2 (Wi-Fi Protected Access)
• 64/128-bit WEP
• Wi-Fi Protected setup (WPS) PBC/PIN
QoS
• Port-based QoS
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11n (5GHz): from MCS0 to MCS15 (up to 300 Mbit/s)
• IEEE 802.11n (2.4GHz): from MCS0 to MCS15 (up to 300 Mbit/s)
The output power of the transmitter
• IEEE 802.11a:
+12 dBm at 54, 48 Mbit/s
+14 dBm at 36, 24 Mbit/s
+15 dBm at 18, 12 Mbit/s
+15 dBm at 9, 6 Mbit/s
• IEEE 802.11b:
+17 dBm at 11, 5.5, 2 and 1 Mbit/s
• IEEE 802.11g:
+14 dBm at 54, 48 Mbit/s
+15 dBm at 36, 24 Mbit/s
+16 dBm at 18, 12 Mbit/s
+16 dBm at 9, 6 Mbit/s
• IEEE 802.11n:
5GHz/HT20
12dBm at MCS0~MCS15
5GHz/HT40
12dBm at MCS0~MCS15
2.4GHz/HT-20
+14 dBm at MCS0/8, 1/9
+14 dBm at MCS2/10, 3/11
+14 dBm at MCS4/12, 5/13
+14 dBm at MCS6/14, 7/15
2.4GHz/HT-40
+12 dBm at MCS0/8, 1/9
+12 dBm at MCS2/10, 3/11
+12 dBm at MCS4/12, 5/13
+12 dBm at MCS6/14, 7/15
Receiver sensitivity
• IEEE 802.11a:
-65 dBm at 54 Mbit/s
-66 dBm at 48 Mbit/s
-70 dBm at 36 Mbit/s
-74 dBm at 24 Mbit/s
-77 dBm at 18 Mbit/s
-79 dBm at 12 Mbit/s
-81 dBm at 9 Mbits/s
-82 dBm at 6 Mbit/s
• IEEE 802.11b:
-76 dBm at 11 Mbit/s
-76 dBm at 5.5 Mbit/s
-80 dBm at 2 Mbit/s
-80 dBm at 1 Mbit/s
• IEEE 802.11g:
-82 dBm at 6 Mbit/s
• IEEE 802.11n:
5GHz/HT-20
-82 dBm at MCS0/8
-79 dBm at MCS1/9
-77 dBm at MCS2/10
-74 dBm at MCS3/11
-70 dBm at MCS4/12
-66 dBm at MCS5/13
-65 dBm at MCS6/14
-64 dBm at MCS7/15
5GHz/HT-40
-79 dBm at MCS0/8
-76 dBm at MCS1/9
-74 dBm at MCS2/10
-71 dBm at MCS3/11
-67 dBm at MCS4/12
-63 dBm at MCS5/13
-62 dBm at MCS6/14
-61 dBm at MCS7/15
2.4GHz/HT-20
-82 dBm at MCS0/8
-79 dBm at MCS1/9
-77 dBm at MCS2/10
-74 dBm at MCS3/11
-70 dBm at MCS4/12
-66 dBm at MCS5/13
-65 dBm at MCS6/14
-64 dBm at MCS7/15
2.4GHz/HT-40
-79 dBm at MCS0/8
-76 dBm at MCS1/9
-74 dBm at MCS2/10
-71 dBm at MCS3/11
-67 dBm at MCS4/12
-63 dBm at MCS5/13
-62 dBm at MCS6/14
-61 dBm at MCS7/15
Device management
• Wireless Setup Wizard
• Web-based management using Internet Explorer 6 or later, Firefox 2.0 or later, or another Java-enabled browser
SharePort™ function support
• Allows network sharing of a USB multifunction printer or USB storage drive
LEDs
• AP
• Bridge
• WPS
• Power
Certificates
Order info
DAP-1525 Wireless N300 Dual Band Access Point/Bridge
