DAP-1350EOL EOS
Wireless N Pocket Router/Access Point
Description
ONE DEVICE, THREE WIRELESS FUNCTIONS
The D-Link® Wireless N Pocket Router/Access Point (DAP-1350) features multi-mode functionality you can utilize as a wireless router to create an 11n Wi-Fi network or easily use as an access point to add Wi-Fi to an existing wired network to provide a wireless connection anywhere. The DAP-1350 also functions as a wireless client to easily connect an Ethernet-ready device (such as a desktop PC or game console) to a Wi-Fi network for increased flexibility and added convenience for all your wireless networking needs.
THE WIRELESS ROUTER THAT TRAVELS
Compact and lightweight, the DAP-1350 is small enough to carry with you while traveling and easily sets up to create a powerful 11n Wi-Fi network. Use the DAP-1350 to easily share an Internet connection or to simply connect to an existing wired network in a conference or hotel room, or anywhere a Wi-Fi network is needed. Equipped with a travel case, the compact and lightweight DAP-1350 is the perfect companion for all your business and personal travels.
ADVANCED WIRELESS SECURITY
The DAP-1350 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or the Internet. Support for WPA™ and WPA2™ wireless encryption ensures that you can keep your network traffic safe and secure. Delivering powerful 11n performance with multi-mode functionality and increased mobility, the DAP-1350 is an ideal solution for providing convenient wireless connectivity anywhere Wi-Fi access is needed.
General features
STANDARDS
• IEEE 802.11b
• IEEE 802.11g
• IEEE 802.11n 2.4GHz
• IEEE 802.3u
INTERFACE TYPE
• Mode selection switch (Router / Access Point / Client)
• 10/100 WAN/LAN Port
• USB Port for 3G USB adapters1 and SharePort™ 2
• WPS button
• Reset button
OPERATION FREQUENCIES
2.4 to 2.4835 GHz
OPERATION CHANNELS
• FCC: 11
• ETSI: 13
OPERATION MODES
• Router Mode
• Access Point Mode
• Wireless Client Mode
ANTENNA TYPE
2 Integrated Antennas
SECURITY
• 64/128-bit WEP
• Wi-Fi Protected Access (WPA-PSK, WPA2-PSK)®
• Wi-Fi Protected Setup™ (WPS PIN/PBC)
• MAC Address Filtering
• Disable SSID Broadcast function
LEDs
• Power
• LAN
• WLAN
CERTIFICATIONS
• FCC Class B
• CE
• C-Tick
• Wi-Fi®, WPS/Wi-Fi Protected Setup
• IC
QUALITY OF SERVICE
Wi-Fi Multimedia (WMM)
Certificates
Order info
DAP-1350 Wireless N Pocket Router/Access Point
Pictures
DAP-1350/A1
Front view
Downloads
Support Resources
