DUB-1040EOL EOS
4 Port USB 2.0 Pocket HUB
Description
Add 4 USB 2.0 ports to your computer
With the DUB-1040 4 Port Universal Serial Bus (USB) 2.0 Pocket Hub, easily add USB ports to your computer. Now you can connect up to 4 more USB peripherals such as your digital camera, printer, CD drive, mouse, and flash drive to your notebook computer.
Seamless connection
The DUB-1040 4 Port USB 2.0 Pocket Hub is designed to provide quick and easy access to the 4 USB 2.0 ports. A USB cable is provided to connect to the host computer or another USB hub. Configured directly by the operating system, this USB Pocket Hub operates seamlessly with Microsoft's OpenHCI, Intel's Universal HCI, and USB 2.0's latest specification, EHCI.The USB Pocket Hub supports computers using Microsoft Windows or Mac OSX operating systems.
Easy to use
Connect this tiny device to an available USB port on your notebook computer and your installation is complete. It's that simple.There are no power switches or buttons to press. The DUB-1040 4 Port USB 2.0 Pocket Hub will always be ready to go. Designed especially for PC and Mac notebook users, this device provides a simple, cost-effective USB connectivity solution for your USB peripherals.
Slim-sized, lightweight, take it with you anywhere
Through a built-in USB cable, which can be neatly placed inside a built-in compartment, the DUB-1040 4 Port USB 2.0 Pocket Hub conveniently connects to your notebook PC. Designed to fit into any notebook bag, the compact size of the device will allow you to conveniently carry it with you wherever you go. Experience the ultimate in portability and expandability with the D-Link DUB-1040 4 Port USB 2.0 Pocket Hub.
General features
Standards
• USB specification version 2.0
• USB specification version 1.1*
• USB specification version 1.0
• OHCI (Open Host Controller Interface)
• EHCI (Enhanced Host Controller Interface)
Wiring topology
• Tiered Star
Connectivity
• Up to 127 devices by cascading multiple hubs
Compatible operating systems
• USB 2.0 Speed
• Mac OS X 10.4.6 with USB 2.0 support
• Microsoft Windows XP/Vista/7 with USB 2.0 support
• USB 1.x Speed
• Mac OS 10.4.6 or above with USB 1.x support
• Microsoft Windows XP/Vista/7 with USB 1.x support
Interfaces
• 1 upstream USB Type A (male) plug
• 4 downstream USB Type A (female) ports
Minimum system requirements
• For USB 1.1 Performance
• Windows XP/Vista/7 with USB 1.1 support
• MacoS X 10.4.6 with USB 1.1 support
• For USB 2.0 Performance
• Windows XP/Vista/7 with USB 2.0 support
• MacoS X 10.4.6 and above with USB 2.0 support
Diagnostic LED
• Power On (Blue)
Supplied current
• Bus power (Total power draw of all attached devices cannot exceed 500mA)
Power requirements
• No power adapter
Dimensions
• 76 x 46 x 18 mm
Weight
• 29.8 grams
Operating temperature
• 0В°C to 40В°C
Storage temperature
• -20В°C to 60В°C
Operating humidity
• 5% to 95% (non-condensing)
Storage humidity
• 0% to 95% (non-condensing)
Package contents
• D-Link 4-Port USB 2.0 Pocket Hub
Certifications
• FCC Class B
• CE
• C-Tick
* Using a USB 1.1 port will affect device performance.
All references to speed are for comparison purposes only. Product specifications, size, and shape are subject to change without notice, actual product appearance may differ than that depicted on the packaging.
Certificates
Order info
DUB-1040 4 Port USB 2.0 Pocket HUB
