DCS-8325LH
Smart Full HD Wi-Fi Camera
Description
The mydlink DCS-8325LH Smart Full HD Wi-Fi Camera boasts a wide-angle lens that easily captures your entire room in high-quality 1080p. The AI-Based Intelligent Video Analysis (IVA) software allows you to specify exactly what types of motion you want to be notified about. With the help of Alexa or the Google Assistant*, you can view your camera feed without ever lifting a finger. The app features notifications that display a screenshot when motion is detected, allowing you to immediately call 2 designated contacts and go straight to the live view all with one touch. Have a clear view of what is happening in the dark with the camera’s built-in night vision. The rotatable head and stand allows for better viewing angles even when placed on top of surfaces. All-in-all, this camera will give you peace of mind and ease of use.
AI-Based IVA Helps Reduce Unwanted Notifications
AI-Based Intelligent Video Analytics (IVA) allows you to be notified of human motion as it can distinguish people from other moving objects. Unlike other cameras that bog you down with a never-ending stream of irrelevant motion-detection alerts, this camera is smart enough to send you an alert only when it really matters.
Full-Featured Motion Tracking With the mydlink App**
Using the DCS-8325LH in combination with the mydlink app, you can track specific areas for motion. Multi-zone Motion Detection can create up to 4 independent rectangular zones so that you get an alert when someone or something is moving around specific areas of interest. Boundary-crossing Detection can superimpose a boundary and send alerts when someone has trespassed into your no-go zone. Priority Zones lets you prioritize sensitive areas, so that you know when something or someone has crossed into or out of the zone.
Anytime, Anywhere Access with mydlink Cloud Recording***
Enhanced with mydlink cloud recording support, the DCS-8325LH makes it easy and convenient for you to look after your family and check up on your home or office. With a mydlink cloud recording subscription, you can have a peace of mind by having your video recordings sent automatically to a cloud server. Play cloud recordings or download them to your mobile device anywhere you have Internet.
General features
Hardware Profile
• 1/2.7” Progressive CMOS sensor
• 5 m IR illumination distance
• Minimum illumination:
  • B/W (Night Mode), IR LEDs on: 0 lux
• Built-in Infrared-Cut Removable (ICR) Filter
• Lens focal length 3.0 mm
• Aperture F2.0
• Angle of view (16:9):
  • Horizontal: 126°
  • Vertical: 63°
  • Diagonal: 151°
• Built-in microphone
• Built-in speaker
Image Features
• Configurable image size
• Person Detection
• Multi-zone Motion Detection (up to 4 zones)
• Priority Zone
• Boundary-Crossing Detection
Video Compression
• H.264 format compression
• Max. Resolution: 1080p (1920 x 1080) at up to 30 fps
Audio Support
• MPEG-2 AAC LC
Wireless Connectivity
• 802.11n/g wireless with WPA/WPA2/WPA3 encryption
• Wi-Fi operates on the 2.4 GHz band
• 1T1R supports a maximum data rate of
  • 72.2 Mbps (PHY rate) using 20MHz bandwidth
  • 150 Mbps (PHY rate) using 40MHz bandwidth
• Bluetooth Low Energy 4.0
Network Protocols
• IPv4, IPv6
• DHCP Client
• Bonjour (mDNS and DNS-SD)
• ONVIF Profile S
• RTSP
• RTCP
• RTP/SRTP
• HTTPS
Event Management
• Moving object detection
• Person detection
• Sound detection
• Cloud recording
• SD card recording****
• Push Notifications with a snapshot when the device detects motion/people/sound
• Push Notifications with quick action buttons:
  • Call up to 2 designated contact numbers
  • Live view button
Mobile Support
• mydlink app** for iOS, and Android devices
Physical Parameters
Environment
• For indoor use only
Weight
• 140 g
Dimensions (L x W x H)
• 83.9 x 74.4 x 108.8 mm
Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 5 V DC 2 A (Micro-USB)
Power Consumption
• Maximum 7 W ± 5%
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 70 °C
Humidity
• Operating: 20 to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• LVD
• RCM
• FCC Class B
• IC
• NCC/BSMI
*Alexa service and the Google Assistant may not be available in all regions.
**Please refer to the app’s store page to check whether your device is compatible.
***Subscription required. Please visit mydlink.dlink.com for more details.
****microSD card not included. Supports capacity up to 256 GB.
Certificates
Order info
Pictures
DCS-8325LH/A1
Front view
View from the right
Left side view
Back view
Downloads
Support Resources
