Description
Convenient and reliable video recording
The DNR-322L mydlink network video recorder is a standalone storage device that can record video from up to nine network cameras to a dedicated HDD storage without requiring users to turn on their PC. Empowered by mydlink technology, DNR-322L supports real-time remote monitoring and playback via a web browser using the mydlink website or the NVR’s web GUI. The DNR-322L has the ability to continue recording live while a user is viewing or searching footage at the same time. With complete video management, the DNR-322L’s display and playback ability make it a convenient and effective video recorder.
Versatile monitoring adjustment
Users are provided with a variety of options for viewing and organizing camera footage on-screen. For a system with multiple channels, users can simply drag and drop selected cameras to the viewing area. Camera names and recording statuses are displayed via the on-screen display. A single camera may beviewed full-screen with two-way audio support. Users can control pan/tilt/zoom (PTZ) functions from within the interface or by directly clicking on the video.
Secure storage
Administrators may filter external connections to the NVR by IP address, limiting access and thus increasing security. Administrators may also choose access privileges for users by specifying the cameras they may access. The recorded data can be backed up to additional storage locations periodically or whenever needed. The NVR also includes the option to protect data using a RAID 1 configuration, which duplicates recorded data onto two separate hard drives. In the event of HDD failure, data integrity is maintained on the secondary HDD. The secondary HDD can also be formatted as a file server and mounted to your Windows system as a network drive.
Extensive recording functionality
The DNR-322L’s clear interface allows for easy configuration including compression, resolution, and frame rate for all connected cameras. Once the cameras have been set up, recordings can be made continuously, or according to a user-defined schedule. The NVR also provides event recording based on specific triggers such as when motion is detected.
General features
Software specifications
OS
• Linux
Supported cameras
• Supports all D-Link network cameras. Includes support for auto-discovery, and up to 3 megapixel resolution.
Recording performance
• Max. capacity (NVR mode only):
H.264 1080P (bitrate): 90 Mbps
H.264 720P (bitrate): 90 Mbps
MJPEG 1080P (frame rate): 90 fps
MJPEG 720P (frame rate): 192 fps
• Max. capacity (NVR + File Server mode):
H.264 1080P (bitrate): 68 Mbps
H.264 720P (bitrate): 68 Mbps
MJPEG 1080P (frame rate): 70 fps
MJPEG 720P (frame rate): 150 fps
Camera Search
• UPnP
Audio and video recording
• Synchronized audio & video recording
Compression Format
• H.264, MPEG-4, M-JPEG (for supported cameras)
Video settings
• Resolution, quality, frame rate, enable audio, go to camera interface
Recording type
• Record by schedule, manual, and event-based recording
• Motion-triggered recording
Remote live view
• Supported via Internet Explorer (max. 9 simultaneous channels)
• Supports mydlink portal (max. 1 simultaneous channel)
Remote live view control
• Live view, preset/go, patrol, focus, PTZ functions, snapshot, full
screen, digital zoom, e-map, multiple view (1/4/6/9/16/25/36/48) with duplicated carrier
Remote playback control
• Playback with normal, fast forward/rewind and step forward/rewind
Remote playback
• Supported via Internet Explorer and NVR client
• Playback system with timeline GUI, search by event, area, cameras, date and time
• IE and NVR client support 1-channel
• Digital zoom
Overwrite recording
• Auto recycling when disk storage is full
File export
• Export videos to AVI or ASF file
• Export images to BMP and JPG file
User account
• Additional accounts can be created to allow user access to the system, and specify authorization for camera channels, PTZ, etc
System time
• Set the system time (D-Link NTP, input time, sync with your computer, Daylight Saving Time)
DDNS
• D-Link DDNS server support
Remote backup
• Remote software can backup raw data to redundant storage
• Auto backup of previous day's video to FTP server
System status
• Camera status, system status
• Still picture EMAP support
Network protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• HTTP Server
• PPPoE
• UPnP
• IP filtering
User interface
• mydlink web portal - Internet Explorer 7 or newer
• HTTP Web browser - Internet Explorer 7 or newer (32 bit OS only)
• NVR Search Utility
Hardware specifications
Standards
• IEEE 802.3/u/z
• Auto MDI/MDI-X
• SATA I, II
HDD (Hard Disk Drive)*
• Hard disk control & management via PC
• Reformat disk
• RAID 0**
• RAID 1**
• JBOD
Two reset modes
• Reset firmware GUI button
• HW reset button (hold for 5 seconds)
Flash ROM
• 128 MB
RAM
• 128 MB DDR II
Network interface
• Gigabit Ethernet LAN port (10/100/1000 Mbps)
I/O Ports
• RJ-45 port
• DC-in jack
• USB port for UPS status update (optional)
Certificates
Order info
DNR-322L mydlink Network Video Recorder
