DCS-910EOL EOS
INTERNET CAMERA
Description
PRODUCT DESCRIPTION
The DCS-910/920 is a versatile and unique surveillance solution for your small offce or home.  Unlike a standard webcam, the DCS-910/920 is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance.  The DCS-910/920 can be accessed remotely and controlled from any PC or notebook over the local network or through the Internet via a web browser.  The simple installation and intuitive web-based interface offer easy integration with your Ethernet/Fast Ethernet or 802.11g wireless network.  The DCS-910/920 also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
WIRELESS G CONNECTIVITY
The DCS-920 offers both 802.11g wireless and Ethernet/Fast Ethernet connectivity, making the DCS-920 easy to integrate into your existing network environment.  The DCS-920 works with a 10Mbps Ethernet based network or a 100Mbps Fast Ethernet based network for traditional wired environments and works with 802.11g routers or access points for added fexibility.  The Site Survey feature also allows you to view and connect to nearby wireless networks.
General features
Certificates
Order info
Pictures
DCS-910/A
Front view
Downloads
Support Resources
