DES-1210-08P
8-ports 10/100 Base-TX PoE Web Smart Switch
Where to buy
Description
The DES-1210 Series of Web Smart switches are equipped with 8, 24, or 48 10/100 Mbps ports, 2 10/100/1000BASE-T ports, and 2 combo 10/100/1000BASE-T/SFP ports. The DES-1210 Series integrates advanced management and security functions for enhanced performance and scalability. Support for IPv6 management and configuration ensures your network investment stays protected after upgrading from IPv4. The DES-1210-08P/28P are IEEE 802.3af and IEEE 802.3at1 Power over Ethernet (PoE) compliant switches and provide 15.4-30 W per port1. The PoE/PoE+ ports can power devices such as IP phones, wireless access points, and IP cameras directly through Ethernet cables making deployment much easier. Management options such as SNMP, Web Management, D-Link Network Assistant Utility, and Compact Command Line also make deployment simple. The DES-1210 Series provides a complete and affordable solution that is ideal for small and medium businesses and the enterprise edge.
Seamless Integration
The Web Smart Switch is designed to provide SMB users with complete control over their network. With Ethernet and Gigabit copper ports capable of connecting to existing CAT5/5E/6 twisted-pair cables, these switches eliminate the need for expensive network re-building. The DES-1210 Series allows for flexible connections to a network backbone or server. Additionally, all ports support auto-negotiation of MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports.
Extensive Layer 2 Features
Equipped with a complete lineup of L2 features, these switches include IGMP Snooping, Port Mirroring, Spanning Tree, and Link Aggregation Control Protocol (LACP). IEEE 802.3x Flow Control allows servers to directly connect to the switch for reliable data transfer. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable Diagnostics allow network administrators to quickly examine the quality of the copper cables and also determine the type of cable error.
QoS, Bandwidth Control
The DES-1210 Series supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, which are best suited for video surveillance and VoIP deployments. Auto Surveillance VLAN is a new, industry-leading technology that consolidates surveillance video transmission and data through a single Web Smart Switch, thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures the quality of real-time video for monitoring and control without compromising the flow of conventional network data. The Auto Voice VLAN technology enhances the VoIP service by automatically routing voice traffic from an IP phone to an assigned VLAN. With higher priority and a dedicated VLAN, these features guarantee the quality and security of VoIP traffic. Furthermore, the DSCP markings on Ethernet packets enable different levels of service to be assigned to network traffic. As a result, these voice and video packets take precedence over other packets. In addition, with bandwidth control, network administrators can reserve bandwidth for important functions that might require higher bandwidth or priority.
Secure Your Network
D-Link’s innovative Safeguard Engine protects against traffic flooding caused by virus attacks. The DES-1210 Series also supports 802.1x port-based authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and protects the internal IT network. The DES-1210 Series supports Address Resolution Protocol (ARP) Spoofing Prevention, which prevents the network from being compromised by hackers using spoofed ARPs that pretend to be trusted PCs, servers, routers, or gateways. For added security, DHCP Server Screening filters rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
Versatile Management
The DES-1210 Series provides a D-Link Network Assistant Utility that enables administrators to remotely control their network down to the port level. The D-Link Network Assistant Utility allows customers to easily discover multiple D-Link Web Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC, and the initial setup of the switches will be greatly simplified. Switches within the same L2 network segment that are connected to the user’s PC are displayed on-screen for instant access. This allows extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The DES-1210 Series also supports D-View 6.0 and Compact Command Line Interface (CLI) through Telnet. D-View 6.0 is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
General features
Size
• 7.5” metal case
Interface
• 8 10/100BASE-TX PoE
Port Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted- pair copper)
• IEEE 802.3z Gigabit Ethernet (fiber) ANSI/IEEE 802.3
• Auto-negotiation
• IEEE 802.3x Flow Control
Performance
Switching Capacity
• 1.6 Gbps
64-byte Maximum Forwarding Rate
• 1.19 Mpps
Packet Buffer Memory
• 4.1 Mbits
MAC Address Table Size
• 8K Entries
Flash Memory
• 16 MB
Forwarding Method
• Store and forward
LEDs
• Power (Per Device)
• Link/Active/Speed (Per Port)
PoE Standard
• 802.3af
PoE Capable Ports
• Port 1-8: up to 15.4 watts per port
PoE Power Budget
• 72 watts
Software
L2 Features
• MAC Address Table
  • 8K entries
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• Port Mirroring
  • One-to-One
  • Many-to-One
  • Supports Mirroring for Tx/Rx/Both
• Spanning Tree
  • Supports 802.1D STP 2004 edition
  • Supports 802.1w RSTP
  • Supports Root Restriction (defined in 802.1Q-2005)
• 802.3ad Link Aggregation
  • Max. 4 groups per device/8 ports per group
L2 Multicasting
• Forward all unregistered groups
• Filter all unregistered groups
• MLD snooping
  • Support MLD v1,v2
  • 256 MLD snooping groups
• IGMP Snooping
  • Supports IGMP v1,v2, v3 awareness
  • Supports 256 IGMP snooping groups
  • Supports 64 static multicast address
VLAN
• 802.1Q tagged VLAN
• VLAN Group
  • Max. 256 static VLAN groups
  • Max. 4094 VIDs
• Management VLAN
• Asymmetric VLAN
• Auto Voice VLAN
• Auto Surveillance VLAN
Quality of Service (QoS)
• 802.1p
• Max. 8 queues per port
• Queue Handling
  • Strict
  • Weighted Round Robin (WRR)
• Bandwidth control
• CoS Based on:
  • 802.1p
  • DSCP
  • ToS
  • TCP/UDP port number
  • IPv6 traffic class
• ACL based on:
  • 802.1p priority
  • VLAN
  • MAC address
  • Ethernet type
  • IPv4 and IPv6 address
  • LLC mask
  • DSCP
  • Protocol type
  • IPv6 Traffic Class
• Max. 50 ingress ACL profiles
• Max. 1280 ingress ACL rules
Security
• 802.1x
  • Supports IPv4/IPv6 RADIUS Server
  • Supports Port-based access Control
  • Supports EAP, OTP, TLS, TTLS and PEAP
  • Supports MD5 authentication
  • Supports 802.1x session timeout attribute
• D-Link Safeguard Engine
• DHCP Server Screening
• ARP Spoofing Prevention
• Storm Control
• Traffic Segmentation
• Port Security
• DoS Attack Prevention
• SSLv1/v2/v3 (IPv4/IPv6)
• Smart Binding (IP-MAC-Port Binding, IMPB)
• Duplicate Address Detection (DAD)
Management
• Web-based GUI
• Compact CLI through Telnet
• Telnet Server (IPv4 / IPv6)
• SmartConsole Utility
• SNMP (IPv4 / IPv6)
  • Supports v1/v2c/v3
• SNMP Trap
• System Log
  • Max. 500 log entries
  • Supports IPv4 / IPv6 log server
• SSHv2 (IPv4/IPv6)
• TFTP Client (IPv4 / IPv6)
• BootP/DHCP Client (IPv4 / IPv6)
• LLDP
• LLDP-MED
• SNTP (IPv4/v6)
• DHCP Auto Configuration
• RMON v1
• IPv4/v6 Dual Stack
• DDP (D-Link Discover Protocol)
MIB
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC1757,RFC2819 RMON MIB
• RFC2233 Interface Group MIB
• RFC1398,1643,1650,2358,2665 Ether-like MIB
• RFC2674,4363 802.1p MIB
• IEEE 802.1AB-2005 LLDP-MIB
• ZoneDefense MIB
• DDP MIB
Physical/Environmental
MTBF
• 656,745 hours
Acoustic
• 0 dB
Heat Dissipation
• 289.59 BTU/h
Power Input
• 100 to 240 VAC, 50 to 60 Hz Internal Universal Power Supply
Maximum Power Consumption
• 84.9 watts (PoE on)
• 3.5 watts (PoE off)
Dimensions (W x D x H)
• 190 x 120 x 38 mm (7.45 x 4.72 x 1. inches)
Cooling Fans
• Fanless
Operation Temperature
• -5-45° C (23-113° F)
Storage Temperature
• -20-70°C (-4-158°F)
Operating Humidity
• 5% to 95% non-condensing
EMI
• FCC Class A
• CE Class A
• VCCI Class A
• IC, C-Tick
Safety
• cUL
• CE LVD
• cUL
• CE LVD
Certificates
Order info
DES-1210-08P 8-ports 10/100 Base-TX PoE Web Smart Switch
Optional Management Software
DV-600S  D-View 6.0 Network Management Software (Standard Edition)
DV-600P  D-View 6.0 Network Management Software (Professional Edition)
Optional SFP Transceivers
DEM-310GT  1000BASE-LX, single-mode, 10 km
DEM-311GT  1000BASE-SX, multi-mode, 550 m
DEM-312GT2  1000BASE-SX, multi-mode, 2 km
DEM-314GT  1000BASE-LHX, single-mode, 50 km
DEM-315GT  100BASE-ZX, single-mode, 80 km
DEM-210  100BASE-FX, single-mode, 15 km
DEM-211 100BASE-FX, multi-mode, 2 km
DGS-712 1000BASE-LX, single-mode, 2 km
Optional WDM SFP Transceivers
DEM-330T  1000BASE-LX, Wavelength Tx: 1550 nm, Rx: 1310 nm, single-mode, 10 km
DEM-330R  1000BASE-LX, Wavelength Tx: 1310 nm, Rx: 1550 nm, single-mode, 10 km
DEM-331T  1000BASE-LX, Wavelength Tx: 1550 nm, Rx: 1310 nm, single-mode, 40 km
DEM-331R  1000BASE-LX, Wavelength Tx: 1310 nm, Rx: 1550 nm, single-mode, 40 km
DEM-220T  1000BASE-LX, Wavelength Tx: 1550 nm, Rx: 1310 nm, single-mode, 20 km
DEM-220R  1000BASE-LX, Wavelength Tx: 1310 nm, Rx: 1550 nm, single-mode, 20 km
Pictures
DES-1210-08P/B
Front view
View from the right
Back view
DES-1210-08P/C
Front view
View from the right
Back view
Downloads
Support Resources
