DSN-1100-10EOL EOS
Description
The D-Link® DSN-1100-10 xStack Storage 4x1GbE iSCSI SAN Array provides a smaller, more value-oriented solution for entry-level and SMB customers. The heart of the DSN-1100 is based on the same powerful System-on-a-Chip (SoC) design found in larger arrays such as the DSN-3000 Series of products, but housed in a smaller chassis. Utilizing a 10Gbit iSCSI SoC solution that can handle over 80,000 I/Os per second, the DSN-1100 is capable of supporting 5TBs of raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced). The DSN-1100 can easily be implemented as nearline storage or as a supplement to your primary backup and recovery device. This evolutionary advancement in performance is a testament to
the tightly integrated xStack Storage architecture and is a sharp contrast to the discrete implementation of competing products.
iSCSI for IP Networks
SAN has been traditionally reserved for Fibre Channel networks until the recent introduction of iSCSI extended this powerful yet simple centralized backend storage system to IP networks. By utilizing existing Ethernet technology, the cost associated with separate host bus adapters and the per-Gigabyte cost for storage is signifcantly reduced. iSCSI SANs can leverage the Ethernet infrastructure and standards that are already familiar to your IT staff.
Four 1GbE Interfaces
The DSN-1100 implements four 1GbE ports that support IEEE 802.3ad Link Aggregation Groups (LAG) for full offoad capability. This allows all four ports to be grouped together for up to 425MB/s bandwidth, increasing throughput and redundancy.
System-on-a-Chip (SoC) Implementation
By utilizing a SoC design, the DSN-1100 combines both networking and storage functions into a single specialized Application Specifc Integrated Circuit (ASIC). The SoC solution combines 10Gbps iSCSI, TCP & IP offoad, embedded processors, and storage virtualization frmware onto a single chip. The tight integration of these functions eliminates interoperability, timing, and support issues found in competitive products that offer “discrete implementation” wherein all the various components are chosen separately and then assembled. The DSN-1100 outperforms these discrete implementations and does so at a lower price point, while delivering mission-critical data quickly with state-of-the-art reliability.
RAID for Effciency
The DSN-1100 features fve hot swappable Serial ATA (SATA) disk drive bays supporting 5TB raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced) in RAID level 0, 1, 1+0 and 5 confgurations. You can quickly deploy a SAN using inexpensive SATA disk drives and, depending on your growing storage needs, you can simply add more drives as you go.
Embedded Centralized Storage Management
The embedded, user-friendly IP-SAN Device Manager (IDM) provides comprehensive network storage management. Boasting a rich set of management features, this suite of utilities allows monitoring and control of your SAN via the Storage Management Initiative-Specifcation (SMI-S) command set. Combined with an embedded secure server, users will be able to remotely confgure and monitor their SAN storage subsystems.
Advanced Management Features
The DSN-1100 provides additional advanced features for effcient management of network storage and optimal performance.
For the fastest RAID performance offered in the industry, the D-Link adaptive cache management provides write coalescing and multi-stream read-ahead on a volume basis, optimizing cache utilization and performance in an application-dependent manner. Volatile cache data protection is afforded via an on-board battery that is designed to back up to 1GB of cached memory for at least 72 hours. A write-back or write-through cache memory policy can be selected manually or automatically, depending on the battery’s charge.
VLAN Zoning supports IEEE 802.1q VLAN tagging to segregate traffc into isolated zones for secure access and jumbo frames, improving network throughput and reducing CPU overhead. Volume Virtualization utilizes the concept of storage Extents. Extents are the fundamental building blocks used to enable features such as RAID, online capacity expansion and volume migration. Drives of dissimilar size can be used to create volumes. Growth can occur without volume migration or reconstruction. Single drives can contain multiple and divergent RAID technologies. Volume structure can also provide infrastructure for Snapshot copies.
RAID Support for RAID Levels 0, 1, 1+0 and 5 (striped sets, mirrored sets, striped mirrored sets, and parity sets) allows for different storage options.Online Capacity Expansion and RAID Level Migration are performed online with minimal impact on users. For example, a mirror volume of two drives can easily be converted to a parity volume of three or more drives while users continue to access this storage. Micro Rebuilds provide protection against unresponsive SATA commands by forcing a response within a preset time limit.
An iSCSI array can prove to be a valuable tool to supplement your network storage foundation. Whether providing a low-cost block-based solution for data backup and recovery, replacement of Direct-Attached Storage (DAS) drives, or providing a cost-effective entry-level nearline storage solution, the DSN-1100 can meet all of your immediate needs.
General features
Features
Drive Bays
5
Drive Interface Support
SATA-II Support
System Memory
256MB to 512MB (256MB standard)
Cache Memory
256MB to 1GB (256MB standard)
Battery Backup for Cache
Standard (approximately 72 hours on full charge)
Bandwidth
Up to 425MB/s
Storage Capacity
5TB capacity with 1TB hard drives (support for higher capacity drives as they are introduced)
Supported NICs, iSCSI Accelerators and iSCSI HBAs
(Please see support.dlink.com for latest support information)
+ Intel® Pro 1000MT & XT [1GbE]
+ Intel Pro 10000 CX4 [10GbE]
+ Myricom 10G-PCIE-8A-C+E [10GbE]
+ Chelsio® S310X-SR-XFP [10GbE]
+ Neterion® Xframe® II & Xframe E [10GbE]
+ Alacritech® SES2104ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
+ Alacritech SES2102ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
+ QLogic® 4010C, 4052C, & 4062C
Operating Systems Supported
+ Windows Vista® 32-bit & x64 (Ultimate & Enterprise) with Built-in iSCSI initiator
+ Windows Server® 2003 32-bit & x64 SP1 (Standard & Enterprise) with v2.07 iSCSI initiator
+ Windows Server 2003 R2 32-bit & x64 (Standard & Enterprise) with v2.07 iSCSI initiator
+ Windows® XP Pro 32-bit & x64 with v2.07 iSCSI initiator
+ Windows 2000 Advanced Server with v1.6 & v2.01 iSCSI initiator
+ Red Hat® 7.3
+ Red Hat Enterprise AS update 5
+ SuSE Enterprise Server 10.2 32-bit (x86)
+ SuSE® Professional 9.3 32-bit & x64
+ Mac OS® X (10.4 & 10.5)
iSCSI Network Interface
+ iSCSI Network Interface: Four 1GbE Copper Ports
+ Host Interface: iSCSI Draft 20 compliant initiator
+ Connections: 1,024 hosts
+ CHAP Authentication
+ Access Control of Management
+ iSCSI/TCP/IP Full HW Offload
+ Jumbo Frames Support
+ Link Aggregation Group Support: Yes – Up to four LAGs (IEEE802.3ad Link Aggregation Group)
+ VLAN Support: Up to four 1-to-1 mapping between IP subnet and VLAN. Multiple VLANs per physical port with VLAN tag. All physical ports in LAG belong to same VLAN (IEEE802.1Q Tag)
Volume & RAID Support
+ RAID Controller: Single- Integrated in ASIC
+ RAID Support RAID Levels 0, 1, 1+0 and 5
+ Volumes: 1,024 Virtual Volumes (256 accessible per initiator)
+ Target Nodes 1,024
+ Online Capacity Expansion
+ Hot Swappable Drives
+ Instant Volume Access
+ Free Space Defragmentation
+ Auto-Detection Failed Drive
+ Auto-Rebuild Spare Drive
+ RAID Level Migration
+ Drive Roaming in Power Off (configured drives are not bay-specific)
+ Micro Rebuilds
Storage Management
+ Embedded IP-based Management GUI
- Create, manage, expand and monitor storage pool, volumes, and RAID
- Event manager to view and persist events
+ Firmware Field Upgradeable
+ SMI-S Version 1.1
Certificates
Order info
DSN-1100-10 xStack Storage® 4X1GbE iSCSI SAN Array with 5 SATA Bays
