DES-1008D/RVEOL EOS
Description
This 8-Port 10/100BASE-T Fast Ethernet Switch is designed for the small-sized workgroup environment. Desktop size is especially suitable for departmental environment, providing users the best performance/price ratio and competitive pricing. Clear, at-a-glance per-device/per-port LED indicators make users easier to understand and control network status.
The feature of VLAN is spec. in Hardware, which isolates each port and is with one port to be uplink-port with upper layer Switch.
General features
Port packet Filtering/Forwarding Rate
14,880 pps for 10M
148,800 pps for 100M
Network Data Transfer Rate
Ethernet:
- 10Mbps (Half-Duplex)
- 20Mbps (Full-Duplex)
Fast Ethernet:
- 100Mbps Half-Duplex
- 200Mbps Full-Duplex
Number of Ports
- 8-Port 10/100Base-T
Compliant to following standards
- IEEE 802.3 10BASE-T
- IEEE 802.3u 100BASE-TX
- Support Auto-Negotiation for each port
- Support Half/Full-Duplex operations at 10/100Mbps
- Support back pressure at Half-Duplex operation
- IEEE 802.3x Flow Control support
- Auto MDI/MDI-X
- Wire speed reception and transmission
- Store-and-Forward switching method
- supports 1K MAC addresses
- Supports 64KBytes RAM for data buffering
- Extensive front-panel diagnostic LEDs
- Switching Capacity 1.6Gbps
