DES-6504EOL EOS
Description
The DES-6504 is a 12-port 100BASE-FX Fiber Ethernet module for the DES-6500 chassis switch. Designed to take full advantage of the DES-6500 chassis switch's advanced network functions and for linking core switches together , this 100Mbps high-performance fiber module supports the SFF (LC type) connectors for superior performance. With multi-mode fiber-optic cable connections, this module supports traffic passing at distances up to 2km in the full-duplex mode.
The DES-6504 100BASE-FX module is fully compliant with IEEE 802.3u and 802.3x standards, so compatibility is never a concern. With 802.3x compliant support for flow control, your data will arrive with gr eater dependability and less packet loss. The DES-6504 is a perfect solution for the bandwidth hungry network needing greater flexibility, longer cabling distances, and the reliability of a state of the art, laser driven, fiber optic channel.
General features
Standards
- IEEE 802.3u 100BASE-FX
- IEEE 802.3x Flow Control
Protocol
CSMA/CD
Data Transfer Rate
- 100Mbps half duplex
- 200Mbps full duplex
Topology
Star
Number of Ports
12 fiber Ethernet ports
Connectors
12 SFF LC
Network Cable
1310nm multi-mode fiber
Maximum Cable Distance
Up to 2km
Box Includes
- DES-6504 12-port 100BASE-FX (SFF) module
- Quick Installation Guide
Certificates
Order info
DES-6504 12-Port 100BASE-FX Fiber Ethernet Module for DES-6500 Chassis Switch
