DE-824TPEOL EOS
24-Port Ethernet Hub
Description
This mounted in a 19 "rack 10Mbps hub for workgroups. Each hub has 24 ports for connecting twisted pair, the number of which can be increased by cascading to another hub.
General features
Data transfer rate
10 Mbps
Protocol
CSMA/CD
EMI Certification
FCC Class A, VCCI I, CE A
AC power
100 - 250 V, 50 - 60 Hz
Power consumption
20 W
Dimensions (including mounting brackets)
483 x 44 x 211 mm
Weight
3.03 kg
Operating temperature
0° - 55° C
Humidity
10 - 90 % non-condensing
Certificates
Order info
DE-824TP 24-Port Ethernet Hub
