![](/up/prod/600/DGS-1100-24PME_B1.jpg)
DGS-1100-24P/MEEOL EOS
Gigabit Metro Ethernet Switch 12-port 10/100/1000 Mbps PoE and 12-port 10/100/1000 Mbps
Description
D-Link’s Gigabit Metro Ethernet Switches are ideal for Metro Ethernet applications, providing 16/24 copper connections on upgraded Gigabit Ethernet ports along with Gigabit SFP ports for improved uplink bandwidth if needed. They also offer resilience against electrical spikes with built-in surge protection, giving you a reliable solution you can count on.
D-Link Green/Power Saving Performance
Compliant with IEEE802.3az Energy Efficient Ethernet, these switches consume less energy by cutting down on power consumption when port utilization is low. By deploying EEE devices, users can cut operating costs and even cut down on necessary cooling equipment, helping small and medium-sized businesses stay within their budgets. The DGS-1100/ME Series also features D-Link Green Technology that helps automatically save energy. The switches monitor the link status of every port and will drastically reduce power consumption when a port link is down.
Easy to deploy
The DGS-1100/ME Series support an intuitive D-Link Network Assistant Utility and a command line management interface. The D-Link Network Assistant Utility allows customers to discover all D-Link switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC, and this also makes initial setup of the switches quick and easy. Switches within the same L2 network segment that are connected to the user’s PC are displayed on-screen for instant access. This allows for extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The command line interface enables network administrators to remotely control their network down to the port level.
QoS and Bandwidth Control
The DGS-1100/ME Series supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN consolidates data and surveillance video transmission through a single DGS-1100/ME Series switch, thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data. The Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from an IP phone to an assigned VLAN. With higher priority and individual VLAN, these features guarantee the quality and security of VoIP traffic. Bandwidth Control can reserve bandwidth on a per port basis for important functions that require larger bandwidth or might have high priority.
PoE Support
The DGS-1100-24P/ME delivers Power over Ethernet (PoE) capabilities, making deployment with IP cameras, VoIP phones, and access points much easier. Power cords will become a thing of the past, as the DGS-1100-24P/ME complies with the 802.3af/802.3at standard for PoE and supports a 100 Watt power budget. The 10/100/1000Base-T Ethernet ports mean that even highquality video is no problem.
Easy Troubleshooting
The DGS-1100/ME Series feature Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. The Cable Diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
Advanced Features
The DGS-1100/ME Series is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC white list for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
General features
Size
11-inch Desktop/Rackmount Size, 1U Height
Number of Ports
• 24 10/100/1000 Mbps (Ports 1 to 12 are PoE enabled)
Port Functions
IEEE 802.3 compliant
IEEE 802.3u compliant
IEEE 802.3ab compliance
IEEE802.3af/802.3at (ports 1 through 12)
Supports half/full-duplex operation (full/half at 10/100 Mbps, full at 1000 Mbps)
Auto-negotiation
Auto MDI/MDIX
IEEE 802.3x Flow Control supports Full-Duplex mode
IEEE 802.3az compliant
Performance
Switching Capacity
48 Gbps
Maximum Forwarding Rate
35.71 Mpps
MAC Address Table Size
8K Entries
Packet Buffer
512 Kbits
Flash Memory
8 Mbyte
PoE
PoE Standard
802.3af/ 802.3at
PoE Capable Ports
Port 1 to 12
PoE Power Budget
100 W
LEDs
Power (per device)
Link/Activity/Speed (per port)
Software Features
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Auto Surveillance VLAN
• Voice VLAN
• Asymmetric VLAN
• VLAN Group
• Supports 128 static VLAN groups
• Max. 4094 VIDs
• Multicast VLAN
L2 Features
• Flow Control
• 802.3x Flow Control
• HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• IGMP Snooping
• IGMP v1/v2/v3 awareness Snooping
• Supports 64 Groups
• IGMP Snooping Querier
• MLD Snooping
• MLD v1/v2 awareness snooping
• Supports 64 groups
• MLD snooping querier
• 802.3ad Link Aggregation:
• Support max 12 groups per device and 8 ports per group
• Loopback Detection
• Cable Diagnostics
• LLDP
• Port Mirroring
• One-to-One
• Many-to-One
• Statistics
• Tx Ok
• Tx Error
• Rx Ok
• Rx Error
• Spanning Tree Protocol
• 802.1D STP
• 802.1w RSTP
Quality of Service (QoS)
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
• Strict
• Weighted Round Robin (WRR)
• Port-based Bandwidth Control (Rate Limiting)
• Ingress: 8Kbps, Egress : 64Kbps
Security
• D-Link Safeguard
• Traffic Segmentation
• DoS Attack Prevention
• Broadcast/Multicast/Unknown Unicast Storm Control
Management
• Command line interface (via Telnet)
• D-Link Network Assistant Utility
Green Technology
• Power Saving by
• Link Status
• LED Shut-Off
• Port Shut-Off
• System Hibernation
• Compliant with IEEE 802.3az Energy Efficient Ethernet
MIB/RFC Standards
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC2233 Interface Group MIB
• RFC2665 Ether-like MIB
• 802.1p MIB RFC4363
• ZoneDefense MIB
• Private MIB
• RFC 951 BootP Client
• RFC 1542 BootP/DHCP client
• RFC 4363 802.1p
• RFC 2236 IGMP Snooping
Optional SFP Transceivers
DGS-712 1000 Base-T copper
DEM-310GT 1000BASE-LX, single-mode, 10 km
DEM-311GT 1000BASE-SX, multi-mode, 550 m
DEM-312GT2 1000BASE-SX, multi-mode, 2 km
DEM-314GT 1000BASE-LHX, single-mode, 50 km
DEM-315GT 100BASE-ZX, single-mode, 80 km
DEM-330T/R Gigabit WDM transceiver, single-mode 10 km
DEM-331T/R Gigabit WDM transceiver, single-mode 40 km
Power Consumption
Maximum Power Consumption
128.32 watts (PoE on)
21.24 watts (PoE off)
Standby Mode
12.94 watts
Physical
Power Input
100 to 240 V AC
50 to 60 Hz Internal Power Supply
MTBF
563,292 hours
Acoustics
41.9 dB (A)
Heat Dissipation
437.85 BTU/hr
Weight
2.15 kg (4.74 lbs)
Dimensions
280x 230x 44 mm (11.02 x 9.05 x 1.73 inches)
Ventilation
1 Fan
Operating Temperature
-5 to 50 °C (23 to 122 °F)
Storage Temperature
-40 to 70 °C (-40 to 158 °F)
Operating Humidity
0% to 95% non-condensing
Storage Humidity
EMI
FCC Class A, CE Class A, VCCI Class A, C-Tick, BSMI, CCC
Safety
cUL, CE LVD, CB, BSMI, CCC
Certificates
Order info
DGS-1100-24P/ME Gigabit Metro Ethernet Switch 12-port 10/100/1000 Mbps PoE and 12-port 10/100/1000 Mbps
