DES-1008P+EOL EOS
8-Port Unmanaged Switch with 8 PoE Ports
Description
	The DES-1008P+ D-Link 8-Port Unmanaged Switch with 8 PoE Ports enables office users to easily connect and supply power to Power over Ethernet (PoE) devices such as wireless access Points (AP), IP cameras, and IP phones while also allowing more Ethernet devices like computers, printers, and Network Attached Storage (NAS) to be connected to a network. Built with small business users in mind, this compact PoE switch operates quietly, making it ideal for use in virtually any office.
	PoE Versatility
	The DES-1008P+ features 8 10/100BASE-TX ports that support the IEEE 802.3af/at PoE protocol allowing a multitude of PoE devices to be connected to your network. In IEEE802.3af mode, each of the 8 PoE ports can supply up to 15.4 watts, and in IEEE802.3at mode, each of the 8 PoE ports can supply up to 30 watts, allowing users to attach an IEEE 802.3af/at compliant device to the DES-1008P+ without requiring additional power. This eliminates the need of having to place networking devices within close proximity of a power outlet and minimizes cable clutter in awkward places such as ceilings or walls.
	Ease of Use
	No configuration is required and installation is quick and easy. Support for Auto-MDI/MDI-X on all ports eliminates the need for crossover cables for connection to another switch or hub. Auto-negotiation on each port senses the link speed of a network device (either 10Mbps or 100Mbps) and intelligently adjusts for compatibility and optimal performance. When an IEEE 802.3af/at compliant device is attached, power supplied to that device will be automatically adjusted to fit the device. The DES-1008P+ also features diagnostic LEDs, which display status and activity, allowing you to quickly detect and correct problems on the network. Combining the versatility of PoE, and ease of use, the D-Link 8-Port Unmanaged Switch with 8 PoE Ports is
	the ideal choice for adding PoE devices to a small business network.
General features
	Standards
	•  IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
	•  IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
	•  ANSI/IEEE 802.3 NWay auto-negotiation
	•  IEEE 802.3x flow control
	•  IEEE 802.3af Power over Ethernet
	•  IEEE 802.3at Power over Ethernet
	LAN
	•  IEEE 802.3u 100BASE-TX compliance
	•  IEEE 802.3x Flow Control support
	Data Transfer Rates
	•  Fast Ethernet
	•  100 Mbps Half-Duplex
	•  200 Mbps Full-Duplex
	•  Ethernet
	•  10 Mbps Half-Duplex
	•  20 Mbps Full-Duplex
	Functionality
	Port Packet Filtering/Forwarding Rate
	•  148,800 pps for 100 M
	•  14,880 pps for 10 M
	Switching Fabric
	•  1.6 Gbps switching fabric
	Number of Ports
	•  8 10/100 Mbps Fast Ethernet ports
	•  8 PoE ports
	Network Cables
	•  10BASE-T:
	   •  UTP CAT 3/4/5/5e (100 m max.)
	   •  EIA/TIA-586 100-ohm STP (100 m max.)
	•  100BASE-TX
	   •  UTP CAT 5/5e (100 m max.)
	   •  EIA/TIA-568 100-ohm STP (100 m max.)
	Media Interface Exchange
	•  Auto MDI/MDIX adjustment for all ports
	LED Indicators
	•  Link/Activity (per port)
	•  Power (per device)
	Transmission Method
	•  Store-and-forward
	MAC Address Table
	•  2K entries per device
	MAC Address Learning
	•  Automatic update
	Packet Filtering/Forwarding Rates
	•  Ethernet: 14,880 pps per port
	•  Fast Ethernet: 148,800 pps per port
	RAM Buffer
	•  96K bytes
	Topology
	•  Star
	Protocol
	•  CSMA/CD
	Physical
	Dimensions
	•  280 x 125.8 x 44 mm (11.0 x 5.0 x 1.7 inches)
	Weight
	•  1.65 kg (3.63763lbs)
	Power Consumption
	•  Power On (Standby, no PD device connected)
	  •  AC input: 6.9 watts maximum
	•  Maximum: (with 140W PoE device connected)
	  •  AC input: 146 watts
	Heat Dissipation
	  •  AC input: 22.67 BTU/h
	  •  AC input: 486.7 BTU/h
	MTBF
	•  64,207 hours
	Temperature
	•  Operating: 0 to 40 °C (32 to 104 °F)
	•  Storage: -40 to 70 °C
	Humidity
	•  Operating: 0% to 95% non-condensing
	•  Storage: 0% to 95% non-condensing
	Certifications
	•  FCC
	•  CE
	•  CB
	•  CCC
	•  UL/cUL
Certificates
Order info
DES-1008P+ 8-Port Unmanaged Switch with 8 PoE Ports
