DGS-1008A/B1EOL EOS
8-Port 10/100/1000 Switch
Description
	Think Green
	The D-Link DGS-1008A 8-Port 10/100/1000 switch is part of D-Link’s new series of SOHO devices that make use of D-Link’s Green Technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. An energy-efficient power adapter (Energy Star Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
	Conserves Energy
	The DGS-1008A 8-port 10/100/1000 switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or ports connected to computers that have been shut down.
	Environmentally Friendly
	The DGS-1008A was designed with the environment in mind, and is compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
General features
	Key features
	• Built-in D-Link Green Technology
	• Inexpensive Gigabit Ethernet solution for Home/SOHO
	• Eight 10/100/1000Mbps Gigabit Ethernet ports
	• 16Gbps switching fabric
	• Auto MDI/MDIX crossover for all ports
	• Secure store-and-forward switching scheme
	• Full/half-duplex for Ethernet/Fast Ethernet speeds
	• IEEE 802.3x Flow Control
	• Supports 9,216 Byte Jumbo Frames
	• RoHS compliant
	• Plug-and-play installation
	Standards
	• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
	• ANSI/IEEE 802.3 NWay auto-negotiation
	Protocol
	• CSMA/CD
	Data Transfer Rates
	Ethernet:
	• 10Mbps (half duplex)
	• 20Mbps (full duplex)
	Fast Ethernet:
	• 100Mbps (half duplex)
	• 200Mbps (full duplex)
	Gigabit Ethernet:
	• 2000Mbps (full duplex)
	Topology
	• Star
	Network cables
	10BASE-T:
	• UTP CAT 3, 4, 5/5e (100m max.)
	• EIA/TIA-586 100-ohm STP (100m max.)
	100BASE-TX, 1000BASE-T:
	• UTP CAT 5/5e (100m max.)
	• EIA/TIA-568 100-ohm STP (100m max.)
	Media interface exchange
	• Auto MDI/MDIX adjustment for all ports
	LED indicators
	• Per port: Link/Activity/Speed
	• Per device: Power
	Transmission method
	• Store-and-forward
	MAC address table
	• 8K entries per device
	MAC address learning
	• Automatic update
	Packet filtering/forwarding rates
	• Ethernet: 14,880pps per port
	• Fast Ethernet: 148,800pps per port
	• Gigabit Ethernet: 1,488,000pps per port
	RAM buffer
	• 128Kbytes per device
Certificates
Order info
DGS-1008A/B1 8-Port 10/100/1000 Switch
