DES-121GEOL EOS
Gigabit 1000Base-SX Fiber Module
Description
• Conforms to IEEE 802.3z draft 4.2 and 802.3x standard
• 1x1000Base-SX/LX Ethernet Port
• 3M memory buffer support
• Standard auto-negotiation for speed, duplex mode and flow-control for MII and GMII PHYs
• Backpressure option and Limit4 option for half duplex
• Automatic address learning with 4K address entry storage
General features
Dimensions
178 mm x 152 mm x 25 mm
Operating Temperature
0ºC to 45ºC
Operating Humidity
10% to 90% (Non-condensing)
Power Supply
Input rate: 100~240VAC, 50~60Hz
EMI
FCC Class A, CE Mark
Certificates
Order info
DES-121G 1 1000BASE-SX Gigabit fiber port (SC connector)
