DES-128EOL EOS
8-port 10/100M Switch Module
Description
The DES-128 8-port 10/100-TX switch module provides DIP-switches from 1st to 4th to adjust link mode with other network devices. Each port was configured by 2 DIPs, so there are 8 DIPs to set link mode of the first 4 ports. There are three types of link mode can be chosen, which include Auto- negotiation, 100Mbps/Full-duplex and 10Mbps/Full-duplex. The last 4 ports was not designed DIP-switches to do any link mode setting, but these ports support auto-negotiation protocol only.
General features
• 8x auto-sensing 10/100Mbps Ethernet switch ports
• Automatic MDI/MDIX crossover for 10Base-T and 100Base-TX ports
• Auto-negotiation supported
• Back-Pressure-Base flow control on Half-duplex ports
• Pause-Frame-Base flow control on Full-duplex ports
• Store-and-forward technology for abnormal packet filtering
• Non-blocking and Full wire speed forwarding rate
• 4K-entry MAC Address Table
• LED-indicators for 100M, LK/ACT, FD/COL status
Certificates
Order info
DES-128 8 10/100Mbps ports
