Apraksts
The DPH-400SE IP Phone is mainly designed for general office users (from VSE, SOHO to SMB) in VoIP communication. With sophisticated and elegant design, this platform has high performance and can offer versatile features and specifications to meet different environment requirements. It can be installed on LAN/DSL/Cable network environment and registered to SIP registrar Server(s), soft switch(es), IP-PBX(s), or IMS-based system and let SIP-enabled terminals to communicate with. Beyond this, users PC can be connected to this phone instead of LAN directly. Color LCD display on the front panel provides direct visual interface with user. User can use keypad/LCD or Web browser to configure this phone.
Īpašības
Network interface
• 10/100Base-TX PoE WAN port for Internet connection
• 10/100Base-TX LAN port for PC connection
• RJ-11 (EXT) port for key expansion module connection
• RJ-9 port for headset connection
• RJ-9 port for handset connection
• Power DC connector
LCD
• Color LCD
Keypad
• 4 soft keys
• 10 DSS keys
• MWI
• Headset
• RLS (Release key)
• Hold
• Call forward
• Three-party conference
• Phone book
• History
• Redial
• Speaker
• 4 navigation keys and OK key
• 12 dial pad keys, including * and # keys
• Mute
• Volume control key (Vol - / Vol +)
Phone Features
• Multi-user (6 SIP accounts)
• Caller ID display
• Call history: 300 missed calls, 300 received calls, 300 dialed calls
• Phone book (up to 500 contact names and phone numbers)
• XML, LDAP remote phone book
• Day/Time display
• Call/Time display
• 10 selective ring tones (9 ring tones and 1 melody)
• 9 speed dial number
• Incoming call indicator
• Flexible dial map
• Password control for Configuration
• Pre-dial before sending
• Connect with expansion module
• MWI
• SMS
• Keypad lock
• Emergency call
• Customized softkey
Voice Codecs
• G.711a/u (64 kbps)
• G.729A/B (8 kbps)
• G.723.1
• G.722
• G.726-32
Voice Features
• Silence suppression
• Acoustic echo cancellation (G.167)
• Voice Active Detection (VAD)
• Comfort Noise Generation
• Jitter buffer
• DTMF transmitter (SIP info, Transparent, RFC 2833)
• Packet Lost Concealment (PLC)
• HD voice support
Signal, Media & Network Protocols
• SIP RFC 3261
• SDP RFC 2327
• RTP RFC 1889
• IP assignment: Static IP, DHCP and PPPoE
• STUN, static port mapping (for NAT traversal)
• SNTP
• DNS & DNS SRV
• TFTP/FTP/HTTP for Auto Provision
• IP/TCP/UDP/ARP/ICMP
• Router and Bridge modes
Advanced Call Features
• Call hold/resume
• Call mute
• Call transfer (blind, attend & early attended transfer)
• Call forward (busy, no answer, unconditional)
• Call waiting
• Call waiting indication
• Three way conference
• Anonymous call/rejection
• Message waiting indication
• Do Not Disturb
• Auto answer
• Black list
• Limit list
• Auto hangup
• Auto redial
• Ban outgoing
• Hot line
• BLF/Presence
• Intercom
• Call Pickup
• Action URL/Active URL
Network Capabilities
• QoS: IEEE 802.1Q & IEEE 802.1p Compliant
• Diffserv (DSCP)/ToS
• Full range VLAN ID support
• Class of Service support by VLAN Tag
• LLDP
• L2TP VPN/OpenVpn
User Interface and Network Management
• LCD/Keypad UI in English & other Languages
• HTTP (WEB) UI in English & other Languages
• FTP/TFTP/HTTP for firmware remote update
• APS auto-provisioning for firmware and profile upgrade
• Emergence upgrade if firmware corrupted
Physical Parameters & Environmental Conditions
Dimensions (L x W x H)
• 240 x 185 x 45 mm
Weight
• 1 kg
Power Input
• Power adapter (not included in the package contents)
- Output: 5 V DC, 1 A
• Via Ethernet cable (PoE) 802.3af (class 2)
Power Consumption
• Typical: 2.5 W (standby mode)
• Maximum: 2.8 W (conversation mode)
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 60 °C
Humidity
• Operating: 10% to 65% non-condensing
• Storage: 15% to 85% non-condensing
Certificates
• CE Class B
Compatible Equipment
• DPH-400EDM key expansion module
Sertifikāti
Informācija pasūtījumam
DPH-400SE IP Phone with color LCD, 1 10/100Base-TX PoE WAN port and 1 10/100Base-TX LAN port
