DPH-400GE
Enterprise Gigabit VoIP Phone with PoE
Kur iegādāties
Apraksts
The DPH-400GE IP Phone is mainly designed for general office users (from VSE, SOHO to SMB) in VoIP communication. With sophisticated and elegant design, this platform has high performance and can offer versatile features and specifications to meet different environment requirements. It can be installed on LAN /DSL/Cable network environment and registered to SIP registrar Server(s), soft switch(es), IP-PBX(s), or IMS-based system and let SIP-enabled terminals to communicate with. Beyond this, user’s PC can be connected to this phone instead of LAN directly. The phone comes with a plastic Housing and some accessories, including handset, handset cord, keypad, keys and wall-mounting kit. A LCD display on the panel provides direct visual interface with user. User can use keypad/LCD or Web browser to configure this phone.
Īpašības
Network protocols
• SIP RFC 3261
• SIP RFC 2327
• RTP RFC 1889
• STUN, Static port mapping (for NAT traversal)
• SNTP
• DNS & DNS SRV
• TFTP / FTP / HTTP / HTTPS
• IP / TCP / UDP / ARP / ICMP
• Bridge/Route mode
Phone Features:
• Multi-user (5 SIP accounts)
• Caller ID display
• Call History: 300 Missed Calls, 300 Received Calls, 300 Dialed Calls
• Phone book (up to 500 contact names and phone numbers)
• Remote phonebook (up to 4 xml phonebook)
• Day / Time display
• Call / Time display
• 11 Selective Ring tones (9 tones & 3 melodies)
• 9 Speed dial number
• Incoming call indicator
• Flexible dial map
• Password control for Configuration
• Pre-dial before sending
• Connect with expansion module
• MWI
• SMS
• Keypad lock
• Emergency call
Voice Codec:
• G.711a/u (64k bps)
• G.729A/B (8k bps)
• G.723.1
• G.722
• AMR
• AMR-WB
• iLBC
Advance Voice Quality Feature
• Silence Suppression
• Acoustic Echo Cancellation (G.167)
• Voice Active Detection (VAD)
• Comfort Noise Generation
• Jitter Buffer
• DTMF Transmitter (SIP info, Transparent, RFC 2833)
• Packet Lost Concealment (PLC)
• HD Voice handset
Supplementary Call Feature
• Call Hold / Resume
• Call Mute
• Call Transfer (Blind, Attend & Semi Attended Transfer)
• Call Forward (Busy, No answer, Unconditional)
• Call Waiting
• Call waiting Indication
• Three Way Conferences
• Anonymous Call / Rejection
• Message Waiting Indication
• Do Not Disturb
• Auto Answer
• Black list
• Limit list
• Auto hangup
• Auto Redial
• Ban outgoing
• Hotline
• BLF / Presence
• Intercom
• Call Pickup
• Action url / Active uri
Network Capability
• QOS: IEEE 802.1p и IEEE 802.1Q
• Diffserv (DSCP)/ToS
• VLAN ID
• Class of Service Support by VLAN Tag
• LLDP
• L2TP VPN
• OpenVPN
Management
• Web, Telnet and Keypad management
• Management with different account rights
• Upgrade firmware via HTTP / FTP / TFTP
• Auto-provisioning (APS) for firmware and profile upgrade
• Emergence upgrade if firmware corrupted
• TR-069
• Syslog
Power Input
• 5V DC, 1.0A
Power Consumption
• Typical: 2.5 Watt (Standby)
• Max.: 2.8 Watt (Talking)
Temperature & Humidity
• Operating: 0 to 40 degree C, 10% to 65% non-condensing
• Storage: -20 to 60 degree C, 10% to 65% non-condensing
Dimension
• 240 (L) x 185 (D) x 45 (H) mm
Weight
• 1 kg
Certifications
• CE Class B
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DPH-400GE   Enterprise Gigabit VoIP Phone with PoE
Attēli
DPH-400GE/F2
Вид слева
Вид справа
DPH-400GE/F1
Pārlādēt
Skatiet arī
