DAP-1155/A/B1EOL EOS
Wireless N150 Access Point & Router
Apraksts
Wireless Interface
Using the DAP-1155 device, you are able to quickly create a wireless network and let your relatives or employees connect to it virtually anywhere (within the operational range of your wireless network). DAP-1155 can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 150Mbps).
The device supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, the “client” function, WPS, WMM.
Security
DAP-1155 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of DAP-1155 via the user-friendly web-based interface (the interface is available in several languages).
Now you can simply update the firmware: the device itself finds approved firmware on D-Link update server and notifies when ready to install it.
Īpašības
Hardware
Interfaces
• 10/100BASE-TX WAN port
• 10/100BASE-TX LAN port
LEDs
• POWER
• WLAN
• WPS
• LAN
• INTERNET
Buttons
• WPS/RESET button to restore factory default settings and set up secure wireless connection
Antenna
• External detachable omnidirectional antenna (2dBi gain)
Power connector
• Power input connector (DC)
Software
Operation modes
• Router mode
WAN connection types
• PPPoE
• Static IP / Dynamic IP
• PPPoE + Static IP / Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• DHCP server/relay
• DNS relay
• Dynamic DNS
• Static IP routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• Flow control
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
Firewall functions
• IP filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
Management
• Local and remote access to settings through TELNET/WEB (HTTP)
• Multilingual web-based interface for configuration and management
• Support of remote logging
• Ping function
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of “client” function
• WMM (Wi-Fi QoS)
• Managing connected stations
• Advanced settings
Wireless connection rate
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n: from 6.5 to 150Mbps (from MCS0 to MCS7)
Transmitter output power
• 802.11b (typical at room temperature 25 °C)
  18dBm at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
   17dBm at 6, 9, 12Mbps
   16dBm at 18, 24Mbps
   15dBm at 36, 48, 54Mbps
• 802.11n (typical at room temperature 25 °C)
  HT20
   17dBm at MCS0/1/2
   16dBm at MCS3/4/5
   15dBm at MCS6
   14dBm at MCS7
  HT40
   17dBm at MCS0/1/2
   16dBm at MCS3/4/5
   15dBm at MCS6
   14dBm at MCS7
Receiver sensitivity
• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
  -82dBm at 1Mbps
  -80dBm at 2Mbps
  -78dBm at 5.5Mbps
  -76dBm at 11Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
  -85dBm at 6Mbps
  -84dBm at 9Mbps
  -82dBm at 12Mbps
  -80dBm at 18Mbps
  -77dBm at 24Mbps
  -73dBm at 36Mbps
  -69dBm at 48Mbps
  -68dBm at 54Mbps
•802.11n (typical at PER = 10% (1000-byte PDUs))
  HT20
  -82dBm at MCS0
  -79dBm at MCS1
  -77dBm at MCS2
  -74dBm at MCS3
  -70dBm at MCS4
  -66dBm at MCS5
  -65dBm at MCS6
  -64dBm at MCS7
  HT40
  -79dBm at MCS0
  -76dBm at MCS1
  -74dBm at MCS2
  -71dBm at MCS3
  -67dBm at MCS4
  -63dBm at MCS5
  -62dBm at MCS6
  -61dBm at MCS7
Modulation schemes
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Physical Parameters
Dimensions
• 109 x 86 x 22 mm (4.3 x 3.4 x 0.9 in)
Weight
• 95 g (0.21 lb)
Operating Environment
Power
• Output: 12V DC, 0.5A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Access point DAP-1155
• Power adapter DC 12V/0.5A
• Ethernet cable
• Detachable antenna
Sertifikāti
Informācija pasūtījumam
DAP-1155/A/B1 Wireless N150 Access Point & Router
