DIR-830MProjektiem
AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Gigabit Router
Apraksts
Wireless Interface
Using the DIR-830M device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1167Mbps1).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2/WPA3), MAC address filtering, WPS, WMM.
The EasyMesh function is D-Link implementation of mesh networks designed to quickly connect several2 devices into one transport network, for example, when it's required to provide high-quality Wi-Fi coverage without dead zones in living units of complicated planning or it's needed to create a large temporary Wi-Fi network for an outdoor event. Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files. Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router. Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DIR-830M includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN. The SSH protocol support provides more secure remote configuration and management of the router due to encryption of all transmitted traffic, including passwords. In addition, the router supports IPsec and allows to create secure VPN tunnels. Support of the IKEv2 protocol allows to provide simplified message exchange and use asymmetric authentication engine upon configuration of an IPsec tunnel. The router also supports the SkyDNS web content filtering service, which provides more settings and opportunities for safer Internet experience for home users of all ages and for professional activities of corporate users. Now the schedules are also implemented; they can be applied to the rules and settings of the firewall and used to reboot the router at the specified time or every specified time period and to enable/disable the wireless network and the Wi-Fi filter. The new ad blocking function effectively blocks advertisements which appear during web surfing.
Easy configuration and update
You can configure the settings of the wireless router DIR-830M via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English). The configuration wizard allows you to quickly switch DIR-830M to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps. Also DIR-830M supports configuration and management via mobile application for Android and iPhone smartphones. You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
2Up to 6 devices.
Īpašības
Hardware
Processor
• RTL8197FH-VG (1GHz)
RAM
• 128MB, DDR2
Flash
• 16 MB, SPI
Interfaces
• 10/100/1000BASE-T WAN port
• 3 10/100/1000BASE-T LAN ports
LEDs
• Status
Buttons
• PWR button to power on/power off
• RESET/WPS button to restore factory default settings, connect mesh network devices, and set up wireless connection
Antenna
• Four external non-detachable antennas (5dBi gain)
MIMO
• 2 x 2, MU-MIMO
Power connector
• Power input connector (DC)
Software
WAN connection types
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IPv4 / Dynamic IPv4
• Static IPv6 / Dynamic IPv6
• PPPoE + Static IP (PPPoE Dual Access)
• PPPoE + Dynamic IP (PPPoE Dual Access)
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• DHCP server/relay
• Advanced configuration of built-in DHCP server
• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
• Automatic obtainment of LAN IP address (for access point/repeater/client modes)
• DNS relay
• Dynamic DNS
• Static IPv4/IPv6 routing
• IGMP/MLD Proxy
• RIP
• Support of UPnP
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• WAN failover
• Autonegotiation of speed, duplex mode, and flow control / Manual speed and duplex mode setup for each Ethernet port
Firewall functions
• IPv4/IPv6 filter
• MAC filter
• URL filter
• Ad blocking function
• DMZ
• Virtual servers
• Built-in SkyDNS web content filtering service
VPN
• PPTP/L2TP tunnels
• L2TP over IPsec
• IPsec tunnels
• Transport/Tunnel mode
• IKEv1/IKEv2 support
• DES encryption
• NAT Traversal
• Support of DPD (Keep-alive for VPN tunnels)
Management and monitoring
• Local and remote access to settings through SSH/TELNET/WEB (HTTP/HTTPS)
• Bilingual web-based interface for configuration and management (Russian/English)
• Support of D-Link Assistant application for Android and iPhone smartphones
• Support of logging to remote host
• Ping utility
• Traceroute utility
• TR-069 client
• Schedules for rules and settings of firewall, automatic reboot, limitation of wireless client maximum bandwidth, and enabling/disabling wireless network and Wi-Fi filter
• Automatic upload of configuration file from ISP's server (Auto Provision)
Wireless Module Parameters
Standards
• IEEE 802.11ac Wave 2
• IEEE 802.11a/b/g/n
• EEE 802.11k/v
• IEEE 802.11w
Frequency range
The frequency range depends upon the radio frequency regulations applied in your country
• 2400 ~ 2483.5MHz
• 5150 ~ 5350MHz
• 5650 ~ 5850MHz
Wireless connection security
• WEP
• WPA3 (Personal)
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• EasyMesh function
• Support of client mode
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
• Guest Wi-Fi / support of MBSSID
• Rate limitation for wireless network/separate MAC addresses
• Periodic scan of channels, automatic switch to least loaded channel
• Support of 5GHz TX Beamforming
• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
• Support of STBC
Wireless connection rate
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (MCS0–MCS15)
• IEEE 802.11ac (5GHz): from 6.5 to 867Mbps (from MCS0 to MCS9)
Transmitter output power
• 802.11n (typical at room temperature 25 °C)
   2.4GHz/5GHz
   15dBm
• 802.11ac (typical at room temperature 25 °C)
   15dBm
Receiver sensitivity
• 802.11a (typical at PER < 10% (1000-byte PDUs) at room temperature 25 °C)
   -94dBm at 6Mbps
   -92dBm at 9Mbps
   -91dBm at 12Mbps
   -89dBm at 18Mbps
   -86dBm at 24Mbps
   -82dBm at 36Mbps
   -78dBm at 48Mbps
   -77dBm at 54Mbps
• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
   -97dBm at 1Mbps
   -93dBm at 2Mbps
   -93dBm at 5.5Mbps
   -89dBm at 11Mbps
• 802.11g (typical at PER < 10% (1000-byte PDUs) at room temperature 25 °C)
   -95dBm at 6Mbps
   -92dBm at 9Mbps
   -92dBm at 12Mbps
   -89dBm at 18Mbps
   -86dBm at 24Mbps
   -83dBm at 36Mbps
   -78dBm at 48Mbps
   -78dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
   2.4GHz, HT20
   -94dBm at MCS0/8
   -91dBm at MCS1/9
   -88dBm at MCS2/10
   -86dBm at MCS3/11
   -82dBm at MCS4/12
   -78dBm at MCS5/13
   -76dBm at MCS6/14
   -75dBm at MCS7/15
   2.4GHz, HT40
   -90dBm at MCS0/8
   -88dBm at MCS1/9
   -86dBm at MCS2/10
   -82dBm at MCS3/11
   -79dBm at MCS4/12
   -75dBm at MCS5/13
   -73dBm at MCS6/14
   -72dBm at MCS7/15
   5GHz, HT20
   -93dBm at MCS0/8
   -91dBm at MCS1/9
   -88dBm at MCS2/10
   -85dBm at MCS3/11
   -82dBm at MCS4/12
   -77dBm at MCS5/13
   -75dBm at MCS6/14
   -74dBm at MCS7/15
   5GHz, HT40
   -91dBm at MCS0/8
   -87dBm at MCS1/9
   -85dBm at MCS2/10
   -82dBm at MCS3/11
   -79dBm at MCS4/12
   -75dBm at MCS5/13
   -74dBm at MCS6/14
   -71dBm at MCS7/15
• 802.11ac (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
   VHT20
   -94dBm at MCS0
   -90dBm at MCS1
   -88dBm at MCS2
   -85dBm at MCS3
   -82dBm at MCS4
   -78dBm at MCS5
   -76dBm at MCS6
   -74dBm at MCS7
   -70dBm at MCS8
   VHT40
   -91dBm at MCS0
   -88dBm at MCS1
   -86dBm at MCS2
   -83dBm at MCS3
   -79dBm at MCS4
   -74dBm at MCS5
   -73dBm at MCS6
   -71dBm at MCS7
   -67dBm at MCS8
   -64dBm at MCS9
   VHT80
   -87dBm at MCS0
   -84dBm at MCS1
   -81dBm at MCS2
   -79dBm at MCS3
   -75dBm at MCS4
   -71dBm at MCS5
   -69dBm at MCS6
   -67dBm at MCS7
   -64dBm at MCS8
   -62dBm at MCS9
Physical Parameters
Dimensions (L x W x H)
• 188 x 120 x 30 mm (7.4 x 4.72 x 1.18 in)
Weight
• 226 g (0.49 lb)
Operating Environment
Power
• Output: 12V DC, 1A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -10 to 70 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 10% to 90% (non-condensing)
Delivery Package
• Router DIR-830M
• Power adapter DC 12V/1A
• Ethernet cable
Sertifikāti
Informācija pasūtījumam
DIR-830M
Attēli
DIR-830M/A1
View from the right
View from the right
Left side view
Back view
Pārlādēt
Skatiet arī
