![](/up/prod/600/ANT70-1800_B1.jpg)
ANT70-1800
Outdoor Dual-Band Directional Antenna, 14/18 dBi
Apraksts
The ANT70-1800 outdoor directional antenna operates both in 2.4 GHz and 5 GHz frequency bands, has 14 dBi (2.4 GHz) / 18 dBi (5 GHz) gain and N Plug connector.
The ANT70-1800 antenna connects to a wireless device equipped with detachable external antennas, for example access point or router. Standard detachable antennas usually have lesser gain than the ANT70-1800, therefore using the 14/18 dBi ANT70-1800 antenna allows you to extend the 2.4 GHz or 5 GHz wireless network coverage and improve the quality of signal reception/transmission. This antenna is suitable both for outdoor and indoor use. Wide range of operating temperatures (-40 to 80 °C) allows you to use the antenna in harsh environmental conditions. N type connector provides compatibility with the most of outdoor access points, while the optional N Jack & RP-SMA Plug cable allows you to connect the ANT70-1800 to indoor wireless devices.
The ANT70-1800 is ideal for using with wireless devices in the Point-to-Point WDS/WDS+AP mode. Alternatively, Wireless Internet Service Provider (WISP) subscribers can also use this antenna to establish a strong connection between their host and their ISP’s outdoor access point.
Īpašības
Connector
• N Plug
Frequency band
• 2.4 GHz - 2.5 GHz
• 4.9 GHz - 5.875 GHz
Gain
• 14 dBi (2.4 GHz)
• 18 dBi (5 GHz)
VSWR
• 2.0 : 1 Max.
Polarization
• Linear, vertical
HPBW / horizontal
• 30° ± 5° (2.4 GHz)
• 15° ± 3° (5 GHz)
HPBW / vertical
• 15° ± 3° (5 GHz)
Impedance
• 50 Ohms
Power handling
• 50 W
Lightning protection
• DC Ground
Physical Parameters
Dimensions
• 172 x 26 x 218 mm
Weight
• 0.6 kg
Environmental Conditions
Survival wind speed
• 180 km/hr
Operating Temperature
• -40 to 80 °C
Operating Humidity
• 95% @ 25 °C
Sertifikāti
Informācija pasūtījumam
ANT70-1800 Outdoor Dual-Band Directional Antenna, 14/18 dBi
