DCS-700L
Wi-Fi Baby Camera Jr.
Kur iegādāties
Apraksts
Keep an eye on your little one with the DCS-700L Wi-Fi Baby Camera Jr. This portable camera transforms your mobile device into a versatile, yet easy to use baby monitor. Connect to the camera wirelessly or over the Internet so you can check on your infant no matter where you are. It includes a wide array of features to help you care for your child, including motion and sound detection, and night vision. It can even play gentle lullabies to help ease your baby to sleep!
Peace of Mind, Anywhere, Anytime
The Wi-Fi Baby Camera Jr. is specially designed to make it easy for you to care for your baby. Its versatile all-day monitoring turns on night vision automatically when it gets dark, giving you a clear picture day or night so you can keep an eye on things anytime. It’s perfect for use in the home, or even when you’re away; it’s mydlink-enabled, which means  that you can check on your baby remotely over the Internet.
Sophisticated Technology to Keep You Informed
The Wi-Fi Baby Camera Jr. helps alert you to specific events. When it detects movement or loud noises such as crying, it can send you notifications so you can check on your little one immediately. Not only can you see and hear your infant, but you can also comfort them with the sound of your voice through two-way audio.*
Perfectly Portable for Instant Monitoring Anywhere
You can take the Wi-Fi Baby Camera Jr. with you when traveling with your child, even when there is no available Internet connection. Just connect your mobile device to the Wi-Fi Baby Camera Jr.’s wireless network for instant local monitoring, making it perfect for family vacations or just visiting friends. You can even connect it to an external USB battery** for total portability!
Super Simple to Use
Getting started is a snap; the free mydlink Baby app for iPhone, iPad, and Android mobile devices not only guides you step by step through the setup process, but also gives you an easy to use interface for all  the  advanced features of the Wi-Fi Baby Camera Jr. Check on your baby at a glance, pinch to zoom in and out with ease, or play one of five gentle lullabies to soothe your child. You can even take snapshots and video clips and save them directly to your mobile device!***
Īpašības
Camera Hardware Profile
• 1/5” VGA CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination: 0 lux with IR LED on
• Built-in microphone and speaker
• Digital zoom
• Adjustable angle and pivot
• Focal length: 2.44 mm
• Aperture: F2.4
• Angle of view:
  (H) 57°
  (V) 42°
  (D) 68°
External Device Interfaces
• 802.11n wireless
• Reset button
• Direct button
• Power port (Micro-USB)
LEDs
• Link/Activity/Power
• Cloud/Direct Mode
Image Features
• Configurable image size
• Time stamp overlay
Video Compression
• MJPEG format video compression
• JPEG for still images
Video Resolutions
• 640 x 480
• 320 x 240
Audio Support
• PCM
• 5 built-in lullabies
Baby Monitoring Features
• Sound detection with adjustable sensitivity
• Motion detection with adjustable sensitivity
• Sends notifications when sound or motion is detected
• 2-way audio lets you listen and respond to your child*
Mobile App
• mydlink Baby Camera Monitor app available on the App Store® and Google Play™
• Compatible with iPhone and iPad using iOS 5.1.1 or higher
• Compatible with Android smartphones and tablets using Android 4.1 or higher
Network Protocols
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• HTTP
• HTTPS (for configuration)
• UPnP port forwarding
Security
• Administrator protection
• Password authentication
• HTTP authentication
Fiziskie raksturlielumi
Dimensions (L x W x H)
• 70 x 75 x 100 mm
Weight
• 108.2 g
Power Input
• 5 V DC/1.2 A, 50/60 Hz power adapter, 5 V DC/1.5 A, 50/60 Hz power adapter for EU/UK
• Can be powered by an external USB battery with at least 2 A output
Power Consumption
• 4.4 watts max.
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• IC
• C-Tick
* 2-way audio is half-duplex.
** USB battery not included, requires at least 2 A output.
*** iOS version of the app only, feature will be available on Android version in future.
Sertifikāti
Informācija pasūtījumam
Attēli
DCS-700L/Ax
View from the right
Back view
View from the right
Pārlādēt
Skatiet arī
