Apraksts
D-Link ANT50-2000N directional dual polarization antenna for outdoor use can increase the range of your wireless network LAN, operating in the 5GHz band. The antenna can provide a high-speed connection to connect to the 802.11n devices. The antenna is equipped with two connectors for the transmission of two spatial streams.
Point-to-point
ANT50-2000N is ideal for operation in such modes as a point-to-point (WDS), and other modes which require a directional antenna with a high gain. The antenna provides the extension of the local network by combining the two networks LAN, separated physically. Alternatively WISP (Wireless Internet Service Provider) customers can also be used for this antenna installation secure connection between the host and external access point provider.
Weather resistance
Antenna ANT50-2000N has waterproof, rugged housing that conforms to IP67 and provides protection against environmental influences. Moreover, the case is made of a material resistant to corrosion, can withstand severe weather conditions and wind speeds up to 216km/h, providing reliable performance throughout the life cycle. Module lightning protection ANT70-SP can be purchased separately for the protection of the receiver antenna from electrical voltage which could cause damage to other elements of external influences such as lightning.
Installation flexibility
To perform the installation of the antenna ANT50-2000N supplied antenna is set for installation, providing installation of antennas on the mast to provide improved wireless coverage. The package also includes the adapter cable with connectors N-type and RP-SMA for easy connections to the host.
Īpašības
Frequency band
• From 5.15GHz to 5.875GHz
Resistance
• 50 Ohms
Gain
• 12-14dBi (5GHz frequency band)
VSWR
• 2.0: 1 (max)
The maximum gain
• 20dBi
Radiation pattern in the horizontal plane (HPBW/H-PLANE)
• 10°C
Radiation pattern in the vertical plane (HPBW/V-PLANE)
• 10°C
Polarization
• Dual in-line, 45° and -45°
The ratio of foreground and background signal levels (PZO)
• -30dB (max)
Cross-polarization isolation
• 24dB (minimum)
Fiziskie raksturlielumi
Cable
• 2 RP-SMA cables for access points designed for indoor use
Jack
• Two N-type connectors
Allowable power
• 6W (cw)
Lightning protection
• DC Ground
Wind load
• 216km/h
Operating temperature
• From -40°C to 80°C.
Operating humidity
• 95% at 55°C.
Colour and material
• Gray-white, PC UV resistant
Weight
• 1.32kg
Dimensions
• 320 x 320 x 20mm
Impermeability
• IP67
Mount kit
• Pole mount and wall
Sertifikāti
Informācija pasūtījumam
ANT50-2000N 5GHz Dual-Polarized Directional Antenna for External Use
