DCS-37-3EOL
Kur iegādātiesApraksts
Ceiling mount angle bracket for DCS-4602EV, DCS-4603, DCS-4802E cameras. Allows you to adjust the camera vertical field-of-view by 27 degrees.
Īpašības
Accessory Type
• Mounting Brackets
Dimensions (Size)
• 29 x 72,1 mm
Weight
• 73 g
Maximum load
• 4kg
Material
• Polycarbonate
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DCS-37-3 Ceiling Mount Angle Bracket for DCS‑4602EV/4603/4802E
