DCS-6513EOL EOS
Full HD WDR Day & Night Outdoor Dome Network Camera
Apraksts
	The D-Link DCS-6513 Full HD WDR Day & Night Outdoor Dome Network Camera is a high-definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity 3 megapixel progressive scan CMOS sensor with a motorized P-Iris lens and onboard WDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera extremely reliable and ideal for deployment in surveillance applications without the need for accessories.
	High-Quality Video
	The DCS-6513 is equipped with a P-Iris lens that controls the iris with extreme precision. Its built-in stepping motor maintains the Iris opening at an optimal level at all times, resulting in superior image quality, clarity, and depth of field, so you can see every minute detail of the area being monitored. The remote focus function eliminates the need for manual focusing at the camera’s position and allows you to make adjustments from any computer. To maximize bandwidth efficiency and improve image quality, the DCS-6513 provides real-time video compression using the H.264, MPEG-4, and MJPEG codecs, and supports three separate profiles for simultaneous video streaming and recording. This versatility enables a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory. Furthermore, bandwidth requirements can be adjusted in real-time over the network, and recorded video files can be saved to a network attached storage (NAS) device or Micro SD card.
	Continuous Monitoring
	The DCS-6513’s WDR image enhancement gives you improved image quality in environments with uneven or difficult lighting, so you can identify subjects that are backlit or in brightly lit areas. In low-light situations, the IR cut filter automatically slides out of the way to use all available light. The DCS-6513 also has built-in IR LED illuminators with a 20 meter range, allowing the camera to keep watch even in complete darkness. These features work together to give you a reliable surveillance camera capable of monitoring an area 24 hours a day.
	Robust Management Software
	The Full HD WDR Day & Night Outdoor Dome Network Camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered through motion detection or events triggered by digital input devices, keeping administrators informed of any unusual activity.
	Flexible Connectivity Options
	The DCS-6513 has a built-in 802.3af compliant PoE module that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling. In addition, the included digital input and output connector enables connections to external devices such as IR sensors, switches and alarm relays.
Īpašības
	Camera Hardware Profile
	• 1/2.8" 3 Megapixel progressive CMOS sensor
	• 20 meter IR illumination distance
	• Minimum illumination: 0.5 lux (F1.2, color mode), 0 lux (B/W, IR-LED on)
	• Built-in Infrared-Cut Removable (ICR) Filter module
	• 10x digital zoom
	• 3 to 9 mm motorized varifocal lens
	• Aperture: F1.2
	• Angle of view (16:9)
	  (H) 96.4° to 31.6°
	  (V) 51.2° to 17.7°
	  (D) 114.1° to 36.3°
	Camera Housing
	• IP-67 compliant weatherproof housing
	• IK-10 compliant vandal-proof housing
	• Included weathershield
	Image Features
	• Configurable image size, quality, frame rate, and bit rate
	• Time stamp and text overlays
	• Configurable motion detection windows
	• Configurable privacy mask zones
	• Configurable shutter speed, brightness, saturation, contrast, sharpness, zoom, focus, and aperture
	Video Compression
	• Simultaneous H.264/MPEG-4/MJPEG format compression
	• H.264/MPEG-4 multicast streaming
	• JPEG for still images
	Video Resolution
	• 4:3 (at 15 fps):
	  2048x1536
	• 4:3 (at 30 fps):
	  1600x1200
	  1024x768
	  800x600
	  640x480
	  480x360
	  320x240
	  176x144
	• 16:9 (at 30 fps):
	  1920x1080
	  1280x720
	  800x450
	  640x360
	  480x270
	  320x176
	  176x144
	Audio Support
	• G.726
	• G.711
	External Device Interface
	• 10/100 BASE-TX Ethernet port with PoE
	• 1 DI / 1 DO
	• DC 12 V, 100 mA output
	• Micro SD/SDHC
	• Audio input/output
	Network Protocols
	• IPv6
	• IPv4
	• TCP/IP
	• UDP
	• ICMP
	• DHCP client
	• NTP client (D-Link)
	• DNS client
	• DDNS client (D-Link)
	• SMTP client
	• FTP client
	• HTTP/HTTPS
	• Samba client
	• PPPoE
	• UPnP port forwarding
	• RTP/RTSP/RTCP
	• IP filtering
	• QoS
	• CoS
	• Multicast
	• IGMP
	• ONVIF compliant
	Security
	• Administrator and user group protection
	• Password authentication
	• HTTP and RTSP digest encryption
	System Requirements for Web Interface
	• Browser: Microsoft Internet Explorer 7 or higher, Firefox 1.5 or higher, or other Java-enabled browser
	Event Management
	• Motion detection
	• Event notification and uploading of snapshots/video clips via e-mail or FTP
	• Supports multiple SMTP and FTP servers
	• Multiple event notifications
	• Multiple recording methods for easy backup
	Remote Management
	• Take snapshots/video clips and save to local hard drive or NAS via web browser
	• Configuration interface accessible via web browser
	Operating Systems
	• Windows 8/7/Vista/XP/2000
	D-ViewCam™ System Requirements
	• Operating System: Microsoft Windows 7/Vista/XP
	• Web Browser: Internet Explorer 7 or higher
	• Protocol: Standard TCP/IP
	D-ViewCam™ Software Functions
	• Remote management
	• Control and manage up to 32 cameras
	• View up to 32 cameras on one screen
	• Management functions provided in web interface
	• Scheduled recording, motion detection, and manual recording triggers
Sertifikāti
Informācija pasūtījumam
