DCS-3716EOL EOS
Full HD Day & Night WDR Network Camera
Kur iegādāties
Apraksts
High Resolution Surveillance
The D-Link DCS-3716 is a high-end Full HD Day & Night WDR Network Camera, equipped with a 1/2.8”  3 Megapixel WDR Progressive Scan CMOS sensor and a 3.1-8.0 mm DC auto iris lens. The DCS-3716 captures video in both dark and light environments, or even subjects shot against a backlight by neutralizing imperfect lighting and generating a realistic image. In addition, the removable IR-cut filter for day/night functionality provides clear detail and high quality video at any hour of the day. The DCS-3716 incorporates Power over Ethernet (PoE) and an SD card slot, allowing it to be easily installed in a variety of locations.
Multiple Video Streams
The DCS-3716 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which require high image detail. H.264 and MPEG-4 produce a small file size, useful for extended recording or for use in low-bandwidth networks. Additionally, the DCS-3716 supports multicast H.264 MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-3716 includes input and output ports allowing connectivity to external devices such as IR sensors, switches, and alarm relays. It also comes with an RS-485 interface, providing connectivity to an optional pan/tilt enclosure which effectively adds pan/tilt functionality to the DCS-3716. An additional 12 V interface provides power for an optional LED illuminator.
Wide Dynamic Range (WDR) Applications
The Wide Dynamic Range (WDR) function provides clear images even under backlit conditions where the intensity of illumination can vary significantly, making the DCS-3716 perfect for extreme high-contrast environments. For example, when placed indoors, the DCS-3716 will adjust itself to the intense sunlight that may be streaming in through a nearby window. This makes it an ideal solution for security applications.
Īpašības
Camera Hardware Profile
• Sony Exmor 1/2.8” 3 Megapixel progressive CMOS sensor
• Minimum Illumination: 0.5 lux (Color); 0.05 lux (B/W)
• Built-in Infrared-Cut Removable (ICR) Filter module
• WDR SN ratio : 100 dB
• 10X digital zoom
• DC iris Varifocal length: 3.1 mm to 8.0 mm
• Aperture: F1.2
• Angle of view:
   (H) 38.7° to 95.9°
   (V) 29.1° to 71.0°
   (D) 48.3° to 123.1°
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• 3 Configurable privacy masks zone
• Configurable WDR, white balance, shutter speed, brightness, saturation, contrast, sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• JPEG for still images
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144
• 4:3 - 2048 x 1536, 1600 x 1200, 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144
• 3M (2048x1536) resolution up to 15 fps, and other resolutions support frame rates up to 30 fps
Audio Support
G.726
External Device Interfaces
• 2 DI / 1 DO
• 12 V DC, 200 mA Output
• RS-485
• SD card slot
• Audio input / output
• Video output
Network Protocols
IPv4, TCP/IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding, RTP / RTSP/ RTCP, IP filtering, 3GPP, IGMP, ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
System Requirements for Web Interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• Event notification and upload snapshots/video clips via HTTP, SMTP, or FTP
• Supports multiple HTTP, SMTP, and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive or NAS via web browser
Mobile Support
• Windows  7/Vista/XP system, Pocket PC, or mobile phone with 3GPP playback support
• D-ViewCam™
System Requirements
• Web Browser: Internet Explorer 6 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Supports all management functions provided in web interface
• Scheduled motion triggered, or manual recording options
Fiziskie raksturlielumi
Power Input
12 V DC 1.25 A, 50/60 Hz, 802.3af PoE
Max. Power Consumption
4 watts
Operating Temperature
0 to 40 ˚C (32 to 104 ˚F)
Storage Temperature
-20 to 70 °C (-4 to 158 °F)
Humidity
20% to 80% non-condensing
Weight
580 g
Certifications
CE (Class A), CE LVD (EN60965-1), FCC (Class A), ICES-003, C-Tick
Sertifikāti
Informācija pasūtījumam
DCS-3716   Full HD Day & Night WDR Network Camera
Attēli
DCS-3716/Ax
Back view
Left side view
View from the right
Pārlādēt
Skatiet arī
