DGS-1210-48EOL
48 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports L2 Smart Managed Switch
Apraksts
The D-Link DGS-1210 Series is the latest generation of switches to provide a range of physical interface types, multiple management interfaces, and advanced Layer 2 features. With all of these features combined, the DGS-1210 Series provides a cost-efficient and flexible solution for expanding any business network.
Seamless Integration
The DGS-1210-48 switch is equipped with 48 10/100/1000Base-T ports and 4 100/1000Base-T/SFP combo ports, allowing you to choose the most suitable media type for your requirements.
D-Link Green
D-Link is constantly striving to take the lead in developing innovative technology that allows for power-saving without sacrificing operational performance or functionality. The DGS-1210-48 switch automatically detects the length of connected cables and can adjust power usage by saving energy on shorter cable connections of up to 20 meters. Link status drastically reduces power consumption by automatically toggling ports without a link to sleep mode. The DGS-1210-48 switch takes the approach to green IT one step further by incorporating a special chipset with advanced silicon technology.
Advanced Features
The DGS-1210-48 switch comes equipped with a complete lineup of L2 features, including IGMP snooping, port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfers. The switch also supports advanced features such as static routes, which allow network administrators to divide the network into VLANs, increasing network efficiency. Network maintenance features include loopback detection and cable diagnostics. Loopback detection significantly speeds up troubleshooting by automatically detecting and shutting down switching loops. The cable diagnostics feature, designed primarily for administrators and customer service representatives, determines the cable quality and quickly discovers errors, allowing for hassle-free diagnostics and maintenance.
Auto Surveillance VLAN and Auto Voice VLAN
The DGS-1210-48 supports Auto Voice VLAN and Surveillance Mode, which allows voice and video traffic to be automatically identified and handled differently to regular network traffic. Auto Voice VLAN detects Voice over IP (VoIP) traffic and automatically segments it from the rest of the network, increasing security and allowing Quality of Service (QoS) to be applied. Surveillance Mode detects compatible ONVIF cameras and places them in a surveillance VLAN, allowing a single switch to be used for voice, video, and data, removing the need for dedicated hardware and reducing maintenance costs. Surveillance Mode also includes its own Web UI, making surveillance features easily accessible and simplifying management of your surveillance network.
Secure your Network
D-Link's innovative Safeguard Engine protects the switches against traffic flooding caused by virus attacks. The switch also supports 802.1X port-based authentication, allowing the network clients to be authenticated through external RADIUS servers. The Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DGS-1210-48 also features Address Resolution Protocol (ARP) spoofing prevention, which provides protection from attacks on the network that could allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages. To prevent ARP spoofing attacks, the switch uses packet control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP server screening feature filters DHCP replies on unauthorized ports to prevent them from being assigned an IP address.
Versatile Management
The DGS-1210-48 supports D-View 8 and Command Line Interface (CLI) through Telnet. D-View 8 is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
Īpašības
Interfaces
• 48 x 10/100/1000Base-T Ports
• 4 x 100/1000Base-T/SFP Combo Ports
LEDs
• Power
• Link/Activity/Speed (per port)
Network Cables
• UTP Cat. 5, Cat. 5e (100 m max.)
Port Standards & Functions
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• Automatic negotiation of Speed and Duplex Mode
• IEEE 802.3x Flow Control
• IEEE 802.3z 1000Base-X
• Auto MDI/MDIX adjustment for all twisted-pair ports
Duplex Mode
• Full/Half-duplex for 10/100 Mbps
• Full-duplex for 1000 Mbps
Performance
Switching Capacity
• 104 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 16K entries
Maximum Packet Forwarding Rate
• 77.4 Mpps
Packet Buffer Memory
• 1.5 MB
Jumbo Frame Size
• 10,000 bytes
Software Features
L2 Features
• MAC Address Table
 - 16K entries
• Static MAC addresses
 - 256 entries
• IGMP Snooping
 - IGMP v1/v2 Snooping
 - IGMP v3 awareness
 - Supports 256 IGMP groups
 - Supports at least 64 static multicast addresses
 - IGMP per VLAN
 - Supports IGMP Snooping Querier
• Loopback Detection
• 802.3ad Link Aggregation:
 - Maximum of 16 groups/8 ports per group
• LLDP
• LLDP-MED
• Jumbo Frame
 - Up to 10,000 bytes
• Spanning Tree Protocol
 - 802.1D STP
 - 802.1W RSTP
 - 802.1s MSTP
• Flow Control
 - 802.3x Flow Control
 - HOL Blocking Prevention
• Port Mirroring
 - One-to-One
 - Many-to-One
 - Supports Mirroring for Tx/Rx/Both
• Multicast Filtering
 - Forwards all unregistered groups
 - Filters all unregistered groups
• Configurable MDI/MDIX
• MLD snooping
 - MLD v1
 - MLD v2 awareness
 - 256 MLD groups
VLAN
• 802.1Q
• VLAN Group
 - Max. 256 static VLAN groups
 - Configurable VID from 1 - 4094
• Asymmetric VLAN
• Auto Voice VLAN
 - Max. 10 user-defined OUI
 - Max. 8 default OUI
• Auto Surveillance VLAN
QoS (Quality of Service)
• 802.1p
• 8 queues per port
• Queue Handling
 - Strict
 - Weighted Round Robin (WRR)
• Bandwidth Control
 - Port-based (ingress/egress, min. granularity 10/100/1000 is 16 Kbps)
• CoS based on
 - 802.1p priority queues
 - DSCP
 - ToS
 - IP precedence
 - IPv6 Traffic Class
 - TCP/UDP port
 - MAC address
 - EtherType
 - IP address
 - Protocol type
L3 Features
• IP interface
 - Supports 4 interfaces
• Static routing
 - 124 IPv4 static route entries
 - 50 IPv6 static route entries
• Max. 50 access lists
• Max. 768 rules shared by IPv4, MAC, and IPv6
• Each rule can only be associated with a single port
• ACL based on
 - VLAN
 - MAC address
 - EtherType
 - IP address
 - DSCP
 - Protocol type
 - TCP/UDP port
 - IPv6 traffic class
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• DHCP Server Screening
• IP-MAC-Port Binding (Smart Binding)
 - ARP Inspection
 - IPv4 Inspection
 - IPv6 Inspection
 - DHCP Snooping
• 802.1X Port-based Access Control
• DoS attack prevention
• ARP Spoofing Prevention
 - Max. 127 entries
• Traffic segmentation
• SSH v2
• TLS v1.3
• Port Security
 - Supports up to 64 MAC addresses per port
AAA
• 802.1X Authentication
 - Supports local/RADIUS database
 - Supports port-based access control
 - Supports EAP, OTP, TLS, TTLS, PEAP
• IPv6 RADIUS server
• Support MD5 authentication
OAM
• Cable Diagnostics
• Factory Reset
Management
• Web-based GUI
• D-Link Network Assistant Utility
• Compact CLI
• Telnet Server
• TFTP Client
• SNMP v1/v2c/v3
• SNMP Trap
• Backup/upgrade firmware
• Smart Wizard
• Upload/download configuration file
• BootP/DHCP Client
• System Log
 - Max. 500 log entries
• SNTP
• ICMP v6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration
• Time setting
 - SNTP
• RMONv1
• Trusted host
• Dual configuration
D-Link Green 3.0 Technology
• Power Saving by:
 - Link status
 - LED shut off
 - Cable length detection
 - Port shut off
 - System hibernation
MIB/RFC Standards
• RFC791 IP
• RFC768 UDP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC826 ARP
• RFC1213 MIB II
• RFC1493 Bridge MIB
• RFC1157, 2573, 2575, 2576 SNMP MIB
• RFC1442, 1901, 1902, 1903, 1904, 1905, 1906, 1907, 1908, 2578, 3418 SNMPv2 MIB
• RFC271, 1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC1321, 2284, 2865, 2716, 3580 Extensible Authentication Protocol (EAP)
• RFC2674 802.1p MIB
• RFC2461, 4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration (SLAAC)
• RFC4291 IPv6 Addressing Architecture
• RFC2893, 4213 IPv4/IPv6 dual stack function
• RFC2233 Interface Group MIB
• RFC2573 SNMP Applications
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC2389 MIB for Diffserv.
• Private MIB
• DDP MIB
• LLDP-MED MIB
Physical & Environmental
Dimensions (L x W x H)
• 440 x 210 x 44 mm
Weight
• 3.46 kg
Power Input
• 100 to 240 V AC 50/60 Hz, internal universal power supply
Maximum Power Consumption
• 34.85 W/100 V
• 34.2 W/240 V
Standby Power Consumption
• 13.7 W/100 V
• 13.9 W/240 V
Heat Dissipation
• 118.92 BTU/hr (100V)
• 116.7 BTU/hr (240V)
MTBF
• 400,667 hours
Acoustics
• 0 dB(A)
Fan Quantity
• 0
Temperature
• Operating: -5• to 50 C
• Storage: -20• to 70 C
Humidity
• Operating: 0% to 95% (Non-condensing)
• Storage: 0% to 95% (Non-condensing)
Certifications
EMI
• CE Class A
• VCCI Class A
• FCC Class A
• BSMI
Safety Certifications
• CB
• UL
• BSMI
• LVD
Sertifikāti
Informācija pasūtījumam
DGS-1210-48/G3A 48 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports L2 Smart Managed Switch
Attēli
DGS-1210-48/G3A
View from the right
View from the right
Back view
Pārlādēt
Skatiet arī
