DGS-1018P
Configurable Switch with 16 1000Base-T PoE Ports, 2 1000Base-X SFP Ports and DIP Switch
Apraksts
The D-Link DGS-1018P 18-Port Gigabit Congigurable PoE Switch offers an economical way for SOHO and Small-to-Medium Businesses (SMB) to take advantage of Gigabit Ethernet speeds, while reducing energy consumption and minimizing noise output.
Gigabit Connectivity
The DGS-1018P brings the speed of Gigabit Ethernet to all ports for a truly high-speed network. If your network has a mix of legacy and modern connection interfaces, each port allows for standard Ethernet, Fast Ethernet, or Gigabit Ethernet connections. You have the latest technology available to every computer and device connected to your network.
Improved Network Efficiency
The DGS-1018P incorporates several advanced features to help simplify and improve network management and efficiency. Flow Control throttles connections to ensure reliability during heavy usage periods by reducing packet loss and wasteful data retransmission. In addition, Storm Control and Port Isolation mitigate the effects of broadcast storms caused by rogue software and malware, which can propagate across the network and bring communication to a standstill.
Innovative Design
The DGS-1018P allows users to quickly enable or disable key port features via the built-in DIP switch to adapt to network needs, including flow control, port isolation & storm control, PD alive, and Extend transmission mode, allowing fast and easy onsite configuration without having to access the web UI. The DGS-1018P also features a durable, compact metal case alongside a smart fan design allowing for improved heat dissipation. The DGS-1018P is rack-mountable and ideal for any business with demanding requirements and a small budget.
DIP Switches for Several Operating Modes
The DGS-1018P has four DIP switches:
- Flow Control - for turning on/off the flow control function;
- Port Isolation & Storm Control - for activating the broadcast storm control and the port isolation functions (in Port Isolation mode, 1 to 15 ports can’t communicate with each other, but each of them can communicate with port 16);
- Extend - the data rate of 1 to 8 port is limited to 10 Mbps, whereas the maximum transmission distance of the port is increased to 250 meters;
- PD Alive - for turning on/off the PD Alive mode, that allows to monitor the availability of the PoE devices connected to ports 1-16 and restart dependent devices in case of power failure.
Long-Reach PoE Connection
The DGS-1018P supports long-range PoE connection configurations, simplifying the issues of distance, power source, and cable deployment for your network systems. Extend connection distances with reduced power transmission loss. Utilize 250 m PoE cable connections at transmission speeds of 10 Mbps. Take advantage of D-Link’s GE PoE Extenders to power devices up to 650 m away, making the DGS-1018P switch the ideal choice for deploying PoE devices to your network, no matter your deployment’s location.
Green Technology
The DGS-1018P helps conserve energy automatically through several methods. Link status detection automatically powers down ports that have no link, allowing the switches to save substantial amounts of power by cutting power usage for unused ports or any ports connected to computers that have been shut down. Energy-Efficient Ethernet (EEE) conserves energy by dynamically reducing power consumption when data activity is low. These environmentally friendly switches are also RoHS compliant, use recyclable packaging, and minimize the use of harmful substances. These green features combined, provide more energy savings and a longer product life, without sacrificing operational performance or functionality.
Īpašības
Number of Ports
• 16 x 10/100/1000Base-T PoE ports
• 2 x 1000Base-X SFP ports
LEDs
• Power
• Link/Activity/Speed (per port)
• PoE (на порт PoE)
• PoE Max
• Fan Error
DIP Switch
• Flow Control
• Port Isolation & Storm Control
• Extend Mode
• PD Alive
Standards
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3z 1000Base-X
• IEEE 802.3x Flow Control
Additional Features
• Power saving by link status
• IEEE 802.1p QoS: 8 queues
Switching Capacity
• 36 Gbps
64 Byte Max. Forwarding Rate
• 26.78 Mpps
Media Interface Exchange
• Auto MDI/MDI-X
Transmission Method
• Store-and-forward
MAC Address Table
• 8K entries
Packet Buffer Memory
• 512 KB
Jumbo Frame
• 9,216 bytes
PoE Standards
• IEEE 802.3at
• IEEE 802.3af
PoE Ports
• Ports 1 to 16
PoE Budget
• 240 W
• Up to 30 W per port
Physical Parameters
Dimensions
• 441 x 210 x 44 mm
Weight
• 3.182 kg
Power Input
• AC Input: 100 to 240 V AC, 50/60 Hz
Power Consumption
• 280.21 W (Maximum)
• 14.102 W (Standby)
MTBF
• 462,928.28 hours
Heat Dissipation
• 280.03 W (956.077 BTU/hr)
Fan
• 2 fans
Acoustics
• 49.5 dB (at fan high speed)
• 21 dB (at fan low speed)
Temperature
• Operating: 0 to 50 °C
• Storage: -10 to 70 °C
Humidity
• Operating: 10% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• FCC
• BSMI
• CE
• RoHS
Safety
• LVD
• BSMI
Sertifikāti
Informācija pasūtījumam
DGS-1018P/B1A
Attēli
DGS-1018P/B1
View from the right
View from the right
Back view
Top view
Pārlādēt
Skatiet arī
