DMS-107Jaunums
7-Port Multi-Gigabit Unmanaged Switch
Apraksts
The DMS-107 7-Port Multi-Gigabit Unmanaged Switch is ideally suited for Small Office Home Office (SOHO) environments. With a durable design, silent operation, and plug-and-play functionality, the DMS-107 switch can be easily set up and be placed in almost any location where network connectivity is required. Support for IEEE 802.3az Energy-Efficient Ethernet (EEE), 802.1p Quality of Service (QoS), and multi-Gigabit Ethernet connection speeds provide advanced features in a compact package.
Integrated Networking
The DMS-107 switch uses auto-sensing ports, providing a small workgroup to flexibly connect Ethernet, Fast Ethernet, Gigabit and 2.5 Gigabit devices to create an integrated network. These ports detect the network speed via auto-negotiation allowing you to get the maximum speed possible for each device connected to your network.
Simplified Installation
All of the ports on the DMS-107 switch supports automatic MDI/MDIX crossover, eliminating the need for crossover cables. Each port can be plugged in directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables. In addition, the DMS-107 switch features multiple front, easy-to-access Ethernet ports with LED indicators per port to easily distinguish link status.
Green Technology
The DMS-107 switch features green technology, such as IEEE 802.3az Energy-Efficient Ethernet (EEE) and link status detection. Energy-Efficient Ethernet reduces power consumption of the switch when network utilization is low, reducing the cost of ownership during periods of inactivity. Link status detection automatically powers down ports when there is no link detected, saving power when the connected device has been shut down or disconnected.
Traffic Management
The DMS-107 switch includes traffic management features, such as IEEE 802.1p Quality of Service (QoS) and IEEE 802.3x Flow Control. The 802.1p QoS feature allows traffic to be classified in 8 priority levels, allowing different types of traffic to be prioritized, depending on their importance. Flow Control will temporarily stop data transmission when the switch’s input buffer is full, helping to minimize dropped packets and providing a more reliable connection for all of your connected devices.
Īpašības
Interfaces
• 5 x 10/100/1000Mbps ports
• 2 x 10/100Mbps/1G/2.5G ports
Standards
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3bz 2.5GBase-T
• IEEE 802.3x Flow Control*
• Auto-MDI/MDIX adjustment on all ports
• IEEE 802.1p QoS**
Diagnostic LEDs
• Power
• Link/Activity/Speed (per port)
Switching Capacity
• 20 Gbps switching fabric
Transmission Method
• Store-and-forward
Packet Filtering / Forwarding Rates
• 14.88 Mpps
MAC Address Table
• 2K entries
MAC Address Learning
• Automatic update
Jumbo Frame Size
• 9,216 byte
Packet Buffer
• 256 KB
Physical Parameters
Dimensions
• 145 x 82 x 28 mm
Weight
• 0.295 kg
DC Input
• External 12 V / 0.5 A power adapter
Maximum Power Consumption
• 3.37 W
Standby Power Consumption
• 0.84 W
MTBF
• 944,277.78 hours
Heat Dissipation
• 4.18 W (14.28 BTU/hr)
Acoustics
• 0 dB
Ventilation System
• Fanless
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 10 to 90% non-condensing
• Storage: 5% to 90% non-condensing
Safety
• LVD
• BSMI
EMI/EMC
• CE Class B
• RCM Class B
• FCC Class B
• VCCI Class B
• IC Class B
• BSMI Class B
* The 2.5G interface supports force mode only.
** Supported on the 1G interface only.
Sertifikāti
Informācija pasūtījumam
DMS-107/A1A
Attēli
DMS-107/A1
View from the right
View from the right
View from the right
Back view
Pārlādēt
Skatiet arī
