![](/up/prod/600/DXS-1210-12SC_B1.jpg)
DXS-1210-12SСProjektiem
10G Smart Switch with 10-port 10G SFP+ and 2-port 10GBase-T/SFP+ combo port
Apraksts
The D-Link DXS-1210-12SC 10 Gigabit/Multi-Gigabit Ethernet Smart Managed Switch is a cost-effective 10 Gigabit switch capable of servicing a range of network needs in any business. Supporting 10GBase-T/SFP+ combo ports, this switch provides connection flexibility across a network allowing easier network integration. With high performance and low latency, the DXS-1210-12SC fulfills the needs for virtualization, cloud services, and server-to-server applications, making it perfect for Small-to-Medium-Business (SMB) customers.
Energy Efficient
By incorporating D-Link Green technology, this switch is capable of saving power without sacrificing operational performance or functionality. The switch features built-in smart fans with internal heat sensors that monitor and detect temperature changes and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run slower, reducing the switch’s power consumption and noise. Link status drastically reduces power consumption by automatically putting ports without a link into a sleep mode. The DXS-1210-12SC takes the approach to green IT one step further by incorporating a special chipset with advanced silicon technology for efficient use of energy.
Extensive Management and Layer 2 Features
The DXS-1210-12SC comes with a complete lineup of L2 features, includes port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). Network maintenance features include loopback detection and cable diagnostics. Loopback detection significantly speeds up troubleshooting by automatically detecting and shutting down difficult to diagnose switching loops. The cable diagnostic feature, designed primarily for administrators and customer service representatives, determines the cable quality and quickly discovers errors, allowing hassle-free diagnostics and maintenance.
Quality of Service and Bandwidth Control
The DXS-1210-12SC supports Auto Surveillance VLAN (ASV) and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN is a new, industry-leading technology that consolidates data and surveillance video transmission through a single DXS-1210-12SC switch, thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures quality real-time video monitoring and control without compromising the transmission of conventional network data. Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from IP phones to a designated VLAN. With higher priority and an individual VLAN, these features guarantee the quality and security of VoIP traffic. The Differentiated Service Code Point (DSCP) markings on Ethernet packets enable different levels of service to be assigned to network traffic. As a result, these voice and video packets take precedence over other packets. In addition, with bandwidth control, network administrators can reserve bandwidth for important functions that require higher priority or more bandwidth.
Secure your Network
D-Link’s innovative Safeguard Engine protects the switch against traffic flooding caused by malicious attacks. The DXS-1210-12SC supports 802.1X port-based and host-based authentication, allowing the network to be authenticated through external RADIUS servers. The Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. For added security, the DHCP server screening feature filters DHCP replies on unauthorized ports to prevent them from being assigned an IP address.
Versatile Management
The DXS-1210-12SC supports D-View and a full Command Line Interface (CLI) through the console port and Telnet. D-View is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
Seamless Integration
The DXS-1210-12SC comes with both RJ-45 and SFP+ ports capable of connecting to Cat. 6 and fiber for 10G Ethernet. The DXS-1210-12SC has 10 SFP+ ports, and 2 10GBase-T/SFP+ combo ports. This means the DXS-1210-12SC can provide a flexible solution for upstream or downstream server connections, making network administration easy.
Īpašības
Interfaces
• 10 SFP+ ports
• 2 100M/1G/2.5G/5G/10GBase-T/SFP+ combo ports
• RJ-45 console port
Port Standard & Functions
• IEEE 802.3u 100Base-TX Fast Ethernet
• IEEE 802.3ab 1000Base-T Gigabit Ethernet
• IEEE 802.3bz 5Gbps and 2.5Gbps Ethernet Over Copper Twisted Pair Cable
• IEEE 802.3an 10GBase-T 10 Gigabit Ethernet
• IEEE 802.3ae 10GbE over fiber
• IEEE 802.3z 1000Base-X
• Auto MDI/MDIX support for 100Base-T/1GBase-T/2.5GBase-T/5GBase-T/10GBase-T
Diagnostic LEDs
• Power
• Fan Error
• Console
• Link/Activity/Speed (Per 10GBase-T port)
• Link/Activity/Speed (Per 10G SFP+ port)
Network Cables for 10GBase-T
• Cat. 6 (30 m max)
• Cat. 6A or Cat. 7 (100 m max)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all twisted-pair ports
Switching Capacity
• 240 Gbps
Maximum Packet Forwarding Rate
• 178.56 Mpps
Transmission Method
• Store-and-forward
MAC Address Table
• Up to 32K entries per device
Packet Buffer
• 2 Mbytes
Flash Memory
• 128 Mbytes
Software Features
L2 Features
• MAC Address Table: Up to 32K entries
• Static MAC Addresses: 1K
• IGMP Snooping:
IGMP v1/v2 Snooping
IGMP v3 awareness
Supports 384 IGMP groups
Supports at least 128 static multicast addresses
Per VLAN IGMP Snooping
Support host-based fast leave
• MLD Snooping:
MLD v1 Snooping
MLD v2 awareness
Support 384 groups
Support 128 static multicast addresses
• LLDP
• LLDP-MED
• Spanning Tree Protocol:
802.1D STP
802.1w RSTP
802.1s MSTP
• Flow Control:
802.3x Flow Control
HOL Blocking Prevention
• Port Mirroring:
One-to-One
Many-to-One
Supports Mirroring for Tx/Rx/Both
• 802.3ad Link Aggregation: Maximum of 8 groups/8 ports per group
• Jumbo Frame: Up to 10KB
• Loopback Detection
VLAN
• 802.1Q VLAN
• Port-based VLAN
• 4K VLAN Groups
• Configurable VID: 1~4094
• Auto Voice VLAN
• Auto Surveillance VLAN
• GVRP
• Asymmetric VLAN
Quality of Service (QoS)
• 802.1p Priority Queue
• 8 queues per port
• Queue Handling:
Strict
Weighted Round Robin (WRR
• Bandwidth Control:
Port-based (Ingress/Egress, min. granularity 64 Kbps)
L3 Features
• IP Interface: Supports 8 IPv4/v6 interfaces
• ARP: 768 Static ARP
• Default Route
• Static Route:
Max. 64 IPv4 entries
Max. 64 IPv6 entries
• Max. 50 access list
• Max. 256 ACL rules
• ACL based on:
802.1p priority
VLAN
MAC address
Ether type
IP address
DSCP
Protocol type
TCP/UDP port number
IPv6 flow label
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• DHCP Server Screening
• Port Security: Supports up to 6656 MAC addresses per port
• Duplicate Address Detection
• Traffic Segmentation
• SSL:
Support v1/v2/v3
Support IPv4/IPv6
• DoS Attack Prevention
• SSH
Operations, Administration, and Management (OAM)
• Cable Diagnostics
Authentication, Authorization, and Accounting (AAA)
• 802.1X Authentication:
Support Dynamic VLAN Assignment
Identity-driven Policy (VLAN/ACL/QoS) Assignment
Supports local/RADIUS database
Supports Port-based access control
Supports Host-based access control
Supports EAP, OTP, TLS, TTLS, PEAP
• Support IPv4/IPv6 RADIUS Server
• Guest VLAN
• Authentication for management access
Management
• Web-based GUI
• Full CLI
• Telnet Server
• TFTP Client
• Configurable MDI/MDIX
• SNMP: Supports v1/v2c/v3
• SNMP Trap
• LLDP
• LLDP-MED
• System Log
• BootP/DHCP Client
• SNTP
• ICMP v6
• IPv4/v6 Dual Stack
• RMON v1
• Trusted Host
• Dual Images
• Dual Configurations
• Debug command
Green V3.0 Technology
• Power Saving by:
Link Status
LED Shutoff
System Hibernation
Port Shutoff
MIB/RFC Standards
• RFC 2021 RMONv2 MIB
• RFC 2460 IPv6
• RFC 2461, RFC 4861 Neighbor Discovery for IPv6
• RFC 2462, RFC 4862 IPv6 Stateless Address Auto-configuration (SLAAC)
• RFC 2463, RFC 4443 ICMPv6
• RFC 2464 IPv6 over Ethernet and definition
• RFC 2465 IPv6 MIB
• RFC 2466 ICMPv6 MIB
• RFC 2474, RFC 3168, RFC 3260 Definition of the DS Field in the IPv4 and IPv6 Headers
• RFC 2571 SNMP Framework
• RFC 2572 SNMP Message Processing and Dispatching
• RFC 2573 SNMP Applications
• RFC 2574 User-based Security Model for SNMPv3
• RFC 2668 802.3 MAU MIB
• RFC 2674, RFC 4363 802.1p MIB
• RFC 271, RFC 1757, RFC 2819 RMON MIB
• RFC 2893, RFC 4213 IPv4/IPv6 dual stack function
• RFC 2925 Ping & TRACEROUTE MIB
• RFC 3513, RFC 4291 IPv6 Addressing Architecture
• RFC 4022 MIB for TCP
• RFC 4113 MIB for UDP
• RFC 4884 Extended ICMP to Support Multi-Part Messages
• RFC 768 UDP
• RFC 792 ICMPv4
• RFC 793 TCP
• RFC 826 ARP
Physical Parameters
Weight
• 2.718 kg
Dimensions
• 440 x 210 x 44 mm
Power Input
• 100 to 240 V AC
Maximum Power Consumption
• 27.4 W
Standby Power Consumption
• 11.2 W
Acoustic
• 46.3 dB (high speed)
• 42.6 dB (low speed)
Heat Dissipation
• 93.64 BTU/hr
MTBF (Hours)
• 554,218.04 hours
Ventilation
• 2 Smart Fans
Temperature
• Operating: -5° to 50°C
• Storage: -40° to 70°C
Humidity
• Operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
EMI/EMC
• CE
• FCC
• IC
• RCM
• VCCI
• BSMI
Safety
• cUL
• CB
• BSMI
Sertifikāti
Informācija pasūtījumam
DXS-1210-12SC/B1A 10G Smart Switch with 10-port 10G SFP+ and 2-port 10GBase-T/SFP+ combo port
