DES-1008C
8 Port SOHO Desktop Switch
Apraksts
The DES-1008C 8 Port SOHO Desktop Switch is economical, plug-and-play networking switch solutions for SOHO and small to medium businesses. It provides eight 10/100 Mbps ports, enabling you to easily expand your network and quickly upgrade your connectivity.
Plug-and-Play Installation
The DES-1008C is plug-and-play device that requires no configuration. You can easily connect multiple computers, share files, music, and video across your home or small office network. 802.3 flow control automatically and efficiently manages the data transmission process without packet loss, providing a more reliable connection for all of your connected devices.
Auto MDI/MDIX CrossOver
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly into a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables, streamlining installation.
Conserve Energy
The DES-1008C implements a power saving function that reduces power to a port when no link to that port is detected.
Īpašības
Interfaces
• 8 x 10/100 Mbps LAN ports
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3x Flow Control
Advanced Features
• Auto MDI/MDIX crossover for all ports
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• Back pressure at half-duplex operation
• Auto-negotiation for each port
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
Functionality
Max. Packet Forwarding Rate
• 1.19Mpps
Switching Fabric
1.6 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 1K entries per device
Packet Filtering/Forwarding Rates
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
Packet Buffer Size
• 56KB
Physical/Environmental
Power
• DC 5 V / 0.55 A
• DC jack: Located on side
Power Consumption
• Power On (Standby): 0.4W
• Maximum: 1.55W
Heat Dissipation
• 5.28 BTU/h
MTBF
• 1,588,251 hours
Ventilation System
• Fanless
Temperature
• Operating: 0 ~ 40 °C
• Storage: - 40 ~ 70 °C
Humidity
• Operating: 10 to 90% non-condensing
• Storage: 5 to 95% non-condensing
Dimensions
• 132x53x21mm
Weight
• 0.0748kgs
EMI/EMS
• CE Report (EMC Directive 2004/108/EC)
• EN 55022 и EN 55024
• EN 61000-3-3
• EN 61000-4-2/3/4/5/6/8/11(ESD/RS/FET/Surge/CS/Magentic/Dip)
• FCC report
• IC report
• C-Tick Report
• BSMI Report
• CNS 13438
• CCC
Safety
• UL/CSA 60950-1
• CB Report
• IEC 60950-1
• CE (LVD report)
• CCC
• BSMI
Sertifikāti
Informācija pasūtījumam
DES-1008C/B1A 8 Port SOHO Desktop Switch
