DIS-PWR40ACEOL EOS
External AC Power Adapter (40 W) for the DIS-200G-12S switch
Apraksts
The DIS-PWR40AC external AC power adapter is an efficient and reliable device, that allows to provide power supply for the DIS-200G-12S switch.
Īpašības
Output Power
• 40 W
Input Voltage Range
• 90 to 264 V AC
Input Voltage Frequency Range
• 47 Hz to 63 Hz
Max. Input Current
• 1.5 A
Max. Inrush Current
• 3.33 A @ 100 V AC, 240 V AC
Efficiency
• 86%
Physical Parameters & Environmental Conditions
Dimensions (L x W x H)
• 110 x 50 x 32 mm
Weight
• 0.218 kg
MTBF
• Over 100 000 hours
Temperature
• Operating: -30 to 60 °C
• Storage: -40 to 50 °C
Humidity
• Storage: 5% to 95% non-condensing
Compatible Equipment
• DIS-200G-12S switch
Sertifikāti
Informācija pasūtījumam
DIS-PWR40AC External AC Power Adapter (40 W) for the DIS-200G-12S switch
