DGS-1100-24P/B1EOL EOS
Gigabit Ethernet Switch
Kur iegādāties
Apraksts
D-Link’s DGS-1100-24P provides an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management.
D-Link Green/Power Saving Performance
Compliant with IEEE802.3az Energy Efficient Ethernet, this switch consumes less energy by cutting down on power consumption when port utilization is low. By deploying IEEE devices, users can cut operating costs and even cut down on necessary cooling equipment, helping small and medium-sized businesses stay within their budgets. The DGS-1100-24P switch also features D-Link Green Technology that helps save energy automatically. The switch monitors the link status of every port and will drastically reduce power consumption when a port link is down.
Easy to deploy
The DGS-1100-24P switch supports an intuitive Client-based utility (D-Link Network Assistant Utility) and a web-based management interface. The Client-based Utility allows customers to discover all switches in the D-Link Smart Switch family within the same L2 network segment. With this utility, users do not need to change the IP address of their PC, and this also makes initial setup of the Smart Switches quick and easy. Switches within the same L2 network segment that are connected to the user’s PC are displayed on-screen for instant access. This allows for extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The graphic web-based management interface provides a user-friendly interface that enables network administrators to remotely control their network down to the port level.
Auto Surveillance VLAN and Bandwidth Control
The DGS-1100-24P switch supports Surveillance VLAN for video surveillance deployment. Surveillance VLAN gives video traffic high priority and an individual VLAN, guaranteeing the quality of surveillance traffic through a single DGS-1100-24P switch, thus sparing businesses the added expenses required for dedicated hardware and facilities. Bandwidth Control can reserve bandwidth on a per port basis for important functions that require larger bandwidth or might have high priority.
Advanced Features
DGS-1100-24P is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC white list for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
Easy Troubleshooting
The DGS-1100-24P switch features Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable Diagnostics helps network administrators quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
PoE Support
The DGS-1100-24P provides support for Power over Ethernet (PoE), making deployment with IP cameras, VoIP phones, and access points much easier. Power cords will become a thing of the past, as the DGS-1100-24P complies with the 802.3af/802.3at standard for PoE and supports a 100 watt power budget. The Gigabit Ethernet ports mean that even high-quality video is no problem.
Īpašības
Hardware Version
• B1
Size
• 11-inch Desktop/rackmount Size, 1U Height
Number of Ports
• 24 10/100/1000 Mbps (Ports 1 to 12 are PoE)
Port Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• IEEE 802.3ab compliance
• IEEE802.3af/802.3at (DGS-1100-24P Ports 1 through 12)
• IEEE 802.3az compliant
• Auto-negotiation
• Auto MDI/MDIX
• IEEE 802.3x Flow Control supports Full-Duplex mode
• Supports half/full-duplex operation (full/half at 10/100 Mbps, full at 1000 Mbps)
Performance
Switching Capacity
• 48 Gbps
Maximum Forwarding Rate
• 35.71 Mpps
MAC Address Table Size
• 8K Entries
Packet Buffer
• 512 Kbits
Flash Memory
• 8 Mbytes
PoE
PoE Standard
• 802.3af/ 802.3at
PoE Capable Ports
• Port 1 to 12
PoE Power Budget
• 100 W (30W max. per PoE port)
Power Consumption
Standby Mode
• 12.94 watts
Maximum Power Consumption
• 128.3 watts (PoE on)
• 21.24 watts (PoE off)
Software Features
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Auto Surveillance VLAN
• Voice VLAN
• Management VLAN
• Asymmetric VLAN
• VLAN Group
  • Supports 128 static VLAN groups
  • Max. 4094 VIDs
L2 Features
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• IGMP Snooping
  • IGMP v1/v2/v3 awareness Snooping
  • Supports 64 Groups
  • IGMP Snooping Querier
• 802.3ad Link Aggregation:
  • Support max 12 groups per device and 8 ports per group
• Loopback Detection
• Cable Diagnostics
• LLDP
• Port Mirroring
  • One-to-One
  • Many-to-One
• Statistics
  • Tx Ok
  • Tx Error
  • Rx Ok
  • Rx Error
• Spanning Tree Protocol
  • 802.1D STP
  • 802.1w RSTP
Quality of Service (QoS)
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
  • Strict
  • Weighted Round Robin (WRR)
• Port-based Bandwidth Control (Rate Limiting)
  • Ingress: 8Kbps, Egress: 64Kbps
Security
• D-Link Safeguard
• Traffic Segmentation
• Broadcast/Multicast/Unknown Unicast Storm Control
• DoS Attack Prevention
• SSL
Management
• Web-based GUI (Supports IPv4/IPv6)
• Client-based Utility (D-Link Network Assistant Utility)
Green Technology
• Power Saving by
  • Link Status
  • LED Shut-Off
  • Port Shut-Off
  • System Hibernation
• Compliant with IEEE 802.3az Energy Efficient Ethernet
MIB/RFC Standards
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 1213 MIB II
• RFC1493 Bridge MIB
• RFC1907 SNMPv2 MIB
• RFC2233 Interface Group MIB
• RFC2665 Ether-like MIB
• 802.1p MIB RFC4363
• ZoneDefense MIB
• Private MIB
• RFC 951 BootP Client
• RFC 1542 BootP/DHCP client
• RFC 4363 802.1p
• RFC 2236 IGMP Snooping
Physical
Power Input
• 100 to 240 V AC
• 50 to 60 Hz Internal Power Supply
MTBF
• 563,292 hours
Acoustics
• 44.5 dB (A)
Heat Dissipation
• 437.85 BTU/hr
Weight
• 2.15 kg (4.74 lbs)
Dimensions
• 280 x 230 x 44 mm (11.02 x 9.05 x 1.73 inches)
Ventilation
• 1 Fan
Operating Temperature
-5 to 50 °C (23 to 122 °F)
Storage Temperature
-40 to 70 °C (-40 to 158 °F)
Operating Humidity
0% to 95% non-condensing
Storage Humidity
EMI
FCC Class A, CE Class A, VCCI Class A, C-Tick, BSMI, CCC
Safety
cUL, CE LVD, CB, BSMI, CCC
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DGS-1100-24P/B1  Gigabit Ethernet Switch
Attēli
DGS-1100-24P/B1/B
View from the right
View from the right
Back view
Pārlādēt
Skatiet arī
