Apraksts
DPS-900 8-slot chassis is designed to accommodate up to eight DPS-200, DPS-300 or DPS-500. This chassis is useful for deployment of eight stackable switches mounted in the same rack.
Using the chassis, users can save space, while their cabling will look neat. The chasses are not equipped with any power supply of their own. All redundant power supply units installed in the chassis will connect directly to their power source. As they are independent units, they are hot-swappable when used with the chassis.
Īpašības
Fiziskie raksturlielumi
Technical specifications:
8-slot chassis for DPS-200/300/500
Physical:
440 x 200.7 x 222.6mm
Weight:
4.58kg
Sertifikāti
Informācija pasūtījumam
