7200-CM3Projektiem
CPU module for the DES-7206 chassis, switch fabric 96 Gbit/s, with ASE support
Kur iegādāties
Apraksts
The CPU module for the DES-7206 chassis, switch fabric 96 Gbit/s, with the support of ASE
Īpašības
Flash Memory
512MB
SDRAM
512MB (expandable to 1GB)
Fiziskie raksturlielumi
Power consumption
50W
Heat dissipation
170.61BTU/hr
MTBF (hours)
174.420
Sertifikāti
Informācija pasūtījumam
7200-CM3  CPU module for the DES-7206 chassis, switch fabric 96 Gbit/s, with ASE support
Attēli
7200-CM3/A
View from the right
View from the right
Pārlādēt
Skatiet arī
