DGS-6600-PWRProjektiem
850W Redundant AC power supply
Kur iegādāties
Apraksts
Īpašības
Output Power
• 850 W
Input Voltage Range
• 90~264 VAC
Input Frequency
• 47~63 Hz
Max. Input Current
• 10 A @ 110 VAC
• 5 A @ 230 VAC
Max. Inrush Current
• 55 A @ 230 VAC
Efficiency
• 85%
Physical Parameters
Dimensions (L x W x H)
• 279.4 x 81.3 x 39.9 mm
Power consumption
• 853.5 W at 110 V
• 853.5 W at 220 V
Heat dissipation
• 2912.4 BTU/hr at 110V
• 2912.4 BTU/hr at 220V
Temperature
• Operating: 0 to 50 C
• Storage: -40 to 70 C
Humidity
• Operating: 10 to 90% non-condensing
• Storage: 5 to 90% non-condensing
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DGS-6600-PWR  850W Redundant AC power supply
Attēli
DGS-6600-PWR/A
View from the right
Pārlādēt
Skatiet arī
