תאור
SHARE USB PRINTERS AND MULTIFUNCTION EQUIPMENT
The DPR-2000 Multi-port Wireless G Print Server lets you share up to
four USB printers among your offce workers across a wired or wireless
network. With four USB 2.0 ports, this print server can create up to
four printer connections from any workstation, so users can send
documents from their PC to the networked printers to print. In addition,
it also supports the scan and fax functions of multifunction equipment,
so users can send faxes directly from their computers, or scan images
without having to attach scanners to their PC. If you plan to cluster
together multiple printers or multifunction equipment at a central
place, this print server can reduce costs and simplify installation.
HIGH PERFORMANCE AND EASE OF USE
Equipped with a powerful CPU and a large buffer RAM, the DPR-2000
performs operations quickly and effciently. All devices attached to it
can print, scan, and fax at the same time, giving you the performance of
four separate single-port print servers at a fraction of the cost. For
wireless connections, an integrated Wi-Fi Protected Setup (WPS) function
allows you to set up a secure connection from this print server to your
wireless router or access point, and then on to all wireless users, in a
matter of minutes.
ACCESS SECURITY AND MULTIPLE OS SUPPORT
The DPR-2000 provides the necessary security by allowing the
administrator to confgure user access right to the network printers and
equipment. It supports a wide range of network operating systems,
including Windows, Mac OS, Linux and Unix. Operation is completely
transparent, so users can enjoy hassle-free performance, fexibility and
compatibility.
REMOTE PRINTING SUPPORT
The DPR-2000 supports the Internet Printing Protocol (IPP), enabling
remote users to output fles to their offce printers even when they are
away from the offce. This print server also provides network
administrators with critical information about the networked printers so
they can monitor the printers’ operation in a timely manner.
מאפיינים כללים
INTERFACE STANDARDS
+ USB 2.0
+ IEEE 802.3, IEEE 802.3u Ethernet
+ IEEE 802.11b/g wireless LAN
DEVICE INTERFACES
+ 4 USB 2.0 ports
+ 802.11b/g wireless LAN
+ 1 10/100BASE-TX Ethernet LAN port
WIRELESS FREQUENCY RANGE
2.4GHz to 2.5GHz
WIRELESS ANTENNA TYPE
PIFA antenna
WIRELESS SECURITY
+ 64/128 bit WEP
+ WPA/WPA2 (Wi-Fi Protected Access)
+ WPS support (Wi-Fi Protected Setup)
DEVICE MANAGEMENT
+ Web-based management through Internet Explorer v6 or later; or other
Java-enabled browsers
+ Print Server setup and management program running under Windows
DIAGNOSTIC LEDs
+ Power
+ Ethernet
+ USB (4 LEDs)
+ Wireless
