DWR-932C
4G/LTE Mobile Router
היכן לקנות
תאור
The DWR-932C 4G/LTE Mobile Router is a 4G LTE Cat4 high speed broadband wireless WAN (WWAN) to Wi-Fi mobile hotspot. The DWR-932C uses a 4G Internet connection to give you an easy-to-set-up Wi-Fi network anywhere you need one. Instead of limiting your mobile Internet connection to a single device through a USB dongle, the DWR-932C allows you to create a Wi-Fi hotspot to share your connection. The convenient size means you can share your connection anywhere; use it in a cafe to send e-mail while your friend reads the news, or at the airport so you and your coworkers can work while waiting for your plane.
Connect Anywhere
Simply insert your data-enabled SIM card to set up your very own mobile Wi-Fi network. The DWR-932C is perfect for when you need to quickly set up an impromptu network; it’s ideal for business trips when you need to share an Internet connection with everybody during a meeting, or use it for travel, allowing you to provide all your travel companions with Internet access.
Security Features Help Protect Your Network
The DWR-932C 4G/LTE Mobile Router is easy-to-use and includes a host of security features. The  built-in firewall helps your neywork resist intrusions over the Internet, while WPA encryption helps prevent unauthorized users from connecting to your network. Wi-Fi Protected Setup (WPS) helps you quickly add new devices with just the touch of a button, getting you connected in no time.
Flexible Usage
The DWR-932C 4G/LTE Mobile Router gives you instant connectivity, all in a powerful yet portable device, that fits easily into your pocket. The rechargeable 2000 mAh Li-ion battery allows you to stay connected for long periods of time, and it’s plug-and-play with no complicated software to install. Getting online with the DWR-932C 4G/LTE Mobile Router is quick, easy, and convenient.
מאפיינים כללים
Interfaces
• 802.11n/g/b wireless LAN
• Standard mini-SIM card interface
• Micro-USB port
Antenna
• Internal LTE antenna: 1x2 MIMO (UL/DL)
• 2 x internal Wi-Fi antenna
LED
• Network type
• Battery status
• Wi-Fi status
• Signal Strength
• SMS
Frequency Support*
• FDD-LTE: Band 1/3/7/8/20; TDD-LTE: Band 38/40
• UMTS/HSDPA/HSUPA: 2100/900 MHz
• GSM/GPRS/EDGE: 900/1800 MHz
Data Throughput**
• Downlink up to 150 Mbps
• Uplink up to 50 Mbps
Security
• WPA/WPA2 PSK Auto (TKIP/AES)
• WPS Push-Button Connection
Advanced Functions
• Built-in firewall
• Built-in NAT
• UPnP
Pshysical Parameters
Power
• DC 5 V/1 A ± 5%
• 2000 mAh Li-ion battery
Dimensions
• 97 x 60 x 16.47 mm
Weight
• 95 g
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 10% to 90% (Non-condensing)
Certifications
• CE
• RoHS
* Supported frequency band is dependent upon regional hardware version.
** Data rates are theoretical. Data transfer rate depends on network capacity and signal strength.
נתונים פיזיים
תקנים
הורדות
DWR-932C/3GG4GI (rev.F1)
איורים
DWR-932C/F1
מראה מקדימה
מראה מקדימה
מראה מימין
Top view
Bottom view
מראה מאחורה
דף מידע
ראה גם
