DSR-500EOL EOS
תאור
D-Link Unified Services Routers provide secure, high performance networking solutions to address the growing needs of small and medium businesses. The integrated high-speed IEEE 802.11n wireless technology in the DSR-250N, DSR-500N, and the DSR-1000N routers offers comparable performance to traditional wired networks, but with fewer limitations. Each router provides optimal network security via features such as Virtual Private Network (VPN) tunnels, IP Security (IPSec), Point-to-Point Tunneling Protocol (PPTP), Layer 2 Tunneling Protocol (L2TP), and Secure Sockets Layer (SSL). These routers also allow you to empower your road warriors with clientless remote access anywhere and anytime using SSL VPN tunnels.
Comprehensive Management Capabilities
The DSR-500/500N and DSR-1000/1000N include dual-WAN Gigabit Ethernet that provides policy-based service management to ensure maximum productivity for your business operations. The failover feature maintains data traffic without disconnecting when a landline connection is lost. The Outbound Load Balancing feature adjusts outgoing traffic across two WAN interfaces and optimizes system performance, resulting in high availability. The second WAN port can be configured as a DMZ port, allowing you to isolate servers from your LAN.
Superior Wireless Performance
Designed to deliver superior wireless performance, the DSR-250N, DSR-500N, and DSR-1000N include 802.11a2/b/g/n, allowing for operation on either the 2.4 GHz or 5 GHz2 wireless LAN radio bands. Multiple In Multiple Out (MIMO) technology allows the DSR-250N, DSR-500N and DSR-1000N to provide high data rates and a wide wireless coverage area with minimized “dead spots.”
Robust VPN Features
A fully featured virtual private network (VPN) provides your mobile workers and branch offices with a secure link to your network. The DSR-250N, DSR-500/500N, and DSR-1000/1000N are capable of simultaneously managing 5, 10, or 20 Secure Sockets Layer (SSL) VPN tunnels respectively, empowering your mobile users by providing remote access to a central corporate database. Site-tosite VPN tunnels use IP Security (IPSec) Protocol, Point-to-Point Tunneling Protocol (PPTP), or Layer 2 Tunneling Protocol (L2TP) to facilitate branch office connectivity through encrypted virtual links. The DSR-250N supports up to 25 simultaneous VPN tunnels, the DSR-500/500N supports up to 35 VPN tunnels, and the DSR-1000/1000N supports up to 70 VPN tunnels.
Efficient Green Technology
As a concerned member of the global community, D-Link is devoted to providing eco-friendly products. D-Link Green Wi-Fi and D-Link Green Ethernet features save power and help cut energy usage costs. The D-Link Green WLAN Scheduler shuts down your wireless network automatically according to a schedule you define, allowing you to turn off your wireless network during off-peak hours, saving energy and keeping your network secure. The D-Link Green Ethernet feature can detect the length of the cables connected to the router, and can adjust power usage accordingly to save energy automatically without sacrificing performance. It can also detect if a link is down on a port, and automatically puts that port into a sleep mode that drastically reduces the amount of power used. In addition, compliance with RoHS (Restriction of Hazardous Substances) and WEEE (Waste Electrical and Electronic Equipment) directives make D-Link Green certified devices an environmentally responsible choice.
מאפיינים כללים
ממשקים
- ממשק Ethernet
2 כניסות WAN 10/100/1000Mbps
2 כניסות LAN 10/100/1000Mbps
- ממשק אלחוטי: 802.11 b\g\n
- 1 כניסה USB
- קונסול: 1 - RJ45
ביצועים
- Throughput: 70Mbps
- VPN: 35Mbps
- Sessions: 30000
- New sessions per sec.: 300
חיבורים
- סטטי\דינמי IP
- PPPoE/L2TP/PPTP
- Multiple PPPoE
ניתוב
- ניתוב סטטי
- ניתוס דינמי
- DNS דינמי: RIPv1, RIPv2, OSPF
- ניתוב בין VLAN
- NAT, PAT
- סינון WEB: כתובות סטטיות, מילות מפתח
- IPS
רשת
- שרת\קליינט
- DHCP Relay
- IEEE802.1q VLAN
- VLAN על בסיס פורט פיזי
- IP Multicast: IGMP Proxy
- IPv6
- Route Failover
- 3G Redundancy
- Outband Load Balancing
VPN
- מנהרות: 35
- אופן הצפנה: DES
- שרת: IPSec/PPTP/L2TP
- IPSec NAT Traversal
- Dead Peer Detection
- IP Encapsulating Security
- Payload
- AH
- VPN Tunnel Keep Alive
- Hub and Spoke
ניהול
- HTTP\HTTPS
- CLI
- SNMP: v1, v2c, v3
